Author Topic: Sex on stick - Pomona 6341  (Read 3414 times)
Offline nukieTopic starter
« on: June 09, 2011, 02:24:56 am »
This is probably the cheapest I've seen anywhere else, ebay link $25
Shipping cost not good for me. Good for you if you are in the US.
Cheaper without all the spare tips
http://www.globaltestsupply.com/c/259/Pomona_6275_Precision_Electronic_Test_Probe_Set.html
« Last Edit: June 09, 2011, 05:50:01 am by nukie »
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Sex on stick - Pomona 6341
« Reply #1 on: June 09, 2011, 08:55:12 am »
I find that spring-loaded points on DMM probes don't  really work. The are fragile and you often need more force than the springs give. It's also harder to hold 2 probes in place with one hand.
Day Job: Mostly LEDs
