Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
Buy/Sell/Wanted
Tektronix DM5120 parts, --- tossed away
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Tektronix DM5120 parts, --- tossed away (Read 532 times)
coromonadalix
Super Contributor
Country:
on:
May 18, 2024, 06:45:42 pm »
Hi this come from an franken modded one loll i had a thread here about heavy modifications in it to make it work outside the frame,
https://www.eevblog.com/forum/testgear/tektronix-dm5120-a-keitley-196-brother/
http://w140.com/tekwiki/wiki/DM5120
manual, service manual etc ... and 2x eeprom dumps there,
But failed in the end, maybe some electrostatic killed the mcu ?
Can do 4 wires on Ohms, MAX 300 Vac Vdc in voltages (No 1000v scale)
parts left
Front panel plate with the pcb / buttons, some are getting stuck when you push them, but nice multi segments digits ... all is good excepts some buttons
The hole multi-meter assembly section
Ie : analog section lm399 etc ...
all is working on this board
, it was tested on the one i rebuilt, all the logic is good
need 5, 15, -15 volts some data clk strobe for the functions, and the output of this board as the SV manual explain, is some sort of contant frequency variable width signal
Could be used in a new dmm project ? all 6 1/2 digit, but 5 1/2 in ac voltage
The main board is defective in the logic, 2x eeproms removed, but it
has a Keithley 196 xformer on it
(still good), this one give all the needed voltages once filtered, you have to compare their schematics to understand why i used it in the DM5120.
photos to / may come later ....
ALL tossed Away thks
Last Edit: May 20, 2024, 01:28:16 am by coromonadalix
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Buy/Sell/Wanted
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
