Item is brand new but open box.
Asking $12000. I’m located in Los Angeles, most likely you will have to be local to purchase this item so you can look at the item and test it.
The MDO3054 is a MDO3000 series mixed domain oscilloscope with 500MHz bandwidth four analogue channels and one 500MHz spectrum analyser input. It is the ultimate 6-in-1 integrated oscilloscope, completely customizable and fully upgradeable. This mixed domain oscilloscope gives fast acquisition, selection record lengths and full suite of automated measurements help solve debug challenges quickly. It complies to UL61010-1:2004, CAN/CSA-C22.2 No. 61010.1: 2004, low voltage directive 2006/95/EC and EN61010-1:2001, IEC 61010-1:2001, ANSI 61010-1-2004, ISA 82.02.01 safety standards and EC council directive 2004/108/EC electromagnetic compatibility.
9inch WVGA (800 x 480) display, rise time is 800ps
2.5GS/s sample rate (1ch), 10M record length
Standard spectrum analyser frequency range 9KHz to 100MHz, optional 9KHz to 3GHz
AFG, logic analyser, protocol analyser, digital voltmeter / frequency counter (optional)
Ethernet, VGA, USBhost and device, AUXOUT, AFG output along with VESA and Kensington lock interfaces
Add, subtract, multiply, divide waveforms arithmetic & integrate, differentiate, FFT math functions
Power source voltage of 100 to 240V ±10%, power source frequency 50 to 60Hz at 100 to 240V
Power consumption 120W maximum
Operating temperature of -10°C to +55°C (14°F to 131°F), up to 40°C, 5% to 90% relative humidity
Dimension is 203.2mm x 416.6mm x 147.4mm (H x W x D), 4.2Kg (9.2lb) net weight
