Author Topic: USB Soldering Iron  (Read 1908 times)
Offline attenchinaTopic starter
  • Country: cn
USB Soldering Iron
« on: September 30, 2018, 01:57:45 am »
Applicable
● Production line
● Institutes
● Enterprises
● Education and Practice
● Maintenance
● Hobby
Features
● Especially suitable for precision welding
● USB standard interface of power bank or adapter supply it with electricity
● Portable design. It can be carried after its handle sleeve is inserted. Don't need to wait it cold down
● Contact temperature-sensed design, make its temperature sensor more sensitive and temperature more accurate
● Smart recognition of working or non-working status
● Multiple soldering tips for option
« Last Edit: October 05, 2018, 03:01:27 am by EEVblog »
http://www.atten.com
Atten soldering iron manufacturer
Offline Brumby
Re: USB Soldering Iron
« Reply #1 on: September 30, 2018, 05:22:53 am »
Applicable
● Production line
I find this a bit hard to accept.  I would be curious to know the use case.
Offline PTR_1275
« Reply #2 on: September 30, 2018, 05:36:48 am »
Same goes for precision welding
Offline rjp
« Reply #3 on: September 30, 2018, 06:04:36 am »
its a combined solder/tig unit.
very handy when you need to repair both the equipment and its electronics after an accident.
Offline PTR_1275
« Reply #4 on: September 30, 2018, 06:14:28 am »
Ahhhhh. Makes sense
We had a opening for a job at work, the ad stated smd experience down to 0603 required. Someone bluffed their way through to an interview, then was asked about their previous soldering experience and the reply was “Yeah, I can weld good”
Offline coromonadalix
« Reply #5 on: September 30, 2018, 07:47:07 am »
wow
They use 3.5 mm audio jack for the exchangeable tips ???
Offline tsman
« Reply #6 on: September 30, 2018, 01:58:22 pm »
Not that strange. Weller uses 3.5mm plugs on their RT range.
Offline CM800
« Reply #7 on: September 30, 2018, 05:51:35 pm »
I don't have much hope for it's functionality....
but it does look GOOD.
