Author Topic: Wanted: Accessories for Differential Probe HP 1141A  (Read 233 times)
Offline mjk64Topic starter
« on: December 26, 2023, 11:26:29 pm »
Hi all!
I got myself an HP 1141A (including the HP 1142A power module), rather cheap
(50 €), but that bargain came at a price: Of all the accessories originally supplied,
I only have the 10x attenuator and a pair of probe pins and their plastic caps,
everything else is missing.
The originally included test board I imported from the US relatively cheap, and I
am now looking mainly for (sorted by decreasing priority):
- Shielded signal lead (01141-68702)
- Probe pins
- Probe pin plastic caps
- The original little case for proper storage -- including the foam insert!
- 100x attenuator (5063-2145)
- AC coupling adapter (5063-2146)
- Five-inch ground lead (5061-6162)[1]
- Two-inch extension leads (package 5) (5959-9334) [2]
- Mini grabbers (1400-1422) [2]
[1] Could build one myself, but maybe HP version is nicer
[2] Already have those in Chinese quality, but maybe HP version is nicer
So if you part with one or more of these accessories, I would love to
hear from you. :) I am located in Germany, but that should not make
a real difference, given how relatively miniscule most of the parts are,
so shipping costs should be no problem. If all else fails, I also have a
US postal address (via https://shipito.com/). PayPal preferred
(will pay all PayPal fees), but SEPA bank transfer is also possible within
the European Union (EU).
See attached excerpts from the original HP Service Manual for a list and
pictures of some of the accessories.
« Last Edit: January 02, 2024, 08:50:52 pm by mjk64 »
