Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
Buy/Sell/Wanted
Wanted: Big air dielectric capacitors (>2 nF)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Wanted: Big air dielectric capacitors (>2 nF) (Read 641 times)
heliosh
Newbie
Country:
on:
June 14, 2019, 08:28:07 am »
Variable or fixed capacity. >1.5 kV.
Logged
woodchips
Frequent Contributor
Country:
Re: Wanted: Big air dielectric capacitors (>2 nF)
Reply #1 on:
June 14, 2019, 11:16:35 am »
Wow, have you worked out how large these will be?
>1.5kV means a plate spacing of >1mm, 2000pF means a very large plate.
Logged
pamphonica
Regular Contributor
Country:
Reply #2 on:
June 17, 2019, 10:11:05 am »
Look for the capacitors used in high-power amateur radio antenna tuning units (ATUs). These are often 1000pF+ and multi kV.
Multiple units can be ganged via the shaft extensions to get larger values.
This chap has been selling good-looking units:
https://www.ebay.co.uk/itm/Variable-air-capacitor-1000pF-2KV-transmitting-13-56MHz-HF-ham-radio/202706490824?hash=item2f323f95c8:g:ntUAAOSwZeRdAoUt
Logged
dzseki
Country:
Reply #3 on:
June 17, 2019, 10:56:15 am »
The one on the picture of the e-bay ad looks like an "Oren Elliott" brand capacitor, they are good at this indeed. Otherwise if you don't need variable capacitance you may conside consider building your own as the construction is really simple. In fact you could have the plates made of 2 layer PCBs, connect and fix the corresponding plates step and repeat, there you go...
Logged
HP 1720A scope with HP 1120A probe, EMG 12563 pulse generator, EMG 1257 function generator, MEV TR-1660C bench multimeter
heliosh
Newbie
Country:
Reply #4 on:
June 17, 2019, 02:07:30 pm »
Yeah I've tried to build one with PVC foil as dielectric and it has molten pretty quickly (not because of arcing)
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #5 on:
June 17, 2019, 03:00:03 pm »
Well yeah, PVC is shite. Do it with PE or PP.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Buy/Sell/Wanted
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Library
