Author Topic: Wanted: FF0290SS1 connector for Owon scope.  (Read 1071 times)
Offline satanistikTopic starter
« on: January 11, 2023, 06:39:37 pm »
I need 90pin connector FF0290SS1 for Owon scope display. It's out of stock in any shop but I can't found any replacement.
Offline coromonadalix
« Last Edit: January 11, 2023, 11:10:16 pm by coromonadalix »
Re: Wanted: FF0290SS1 connector for Owon scope.
« Reply #2 on: January 12, 2023, 08:11:31 pm »
I try FH30-90S-0.3SHW(05) but first - pins have another lenght, if I solder one side, second can't be soldered. I solder it using som wires but it's some difference between flex pads, mowing connector inside socket, I have sometime picture, lines or short.
« Reply #3 on: December 07, 2023, 09:52:08 pm »
Finally, I found this connector and LCD in Compaq 36xx palm, only information i can found is single forum topic when someon have this type of display and writing about use it in project,( I think it's worse to use display on the world, need external IC and 90pin connector), and say something about Compaq palm. After few hours spend on Google graphics, searching PDA boards, I found compaqu 38xx having similar display resolution and 90pin connector, but it's mis, connector is similar but can't be use. Finally in 36xx series I found identical display and connector.
« Last Edit: December 08, 2023, 07:47:55 am by satanistik »
