Author Topic: (Found) WTB - Anyone have a spare HP side handle  (Read 1172 times)
Offline Ground_LoopTopic starter
« on: December 30, 2023, 07:40:23 pm »
I snapped the handle off the right side of my 8567A trying to move it. If anyone has a spare laying around they’re willing to part with I’ll pay a reasonable price. See pic below.
« Last Edit: January 02, 2024, 11:37:04 pm by Ground_Loop »
There's no point getting old if you don't have stories.
Offline MadTux
Re: WTB - Anyone have a spare HP side handle
« Reply #1 on: December 30, 2023, 08:04:29 pm »
Common fate with HP handles and those die cast aluminum front frames ;-/
Looking for some 3U front frames myself, too. TIG welding seems like a nightmare.
Offline deepfryed
« Reply #2 on: December 31, 2023, 08:29:23 am »
You can take the easy way out and try brazing.
« Reply #3 on: December 31, 2023, 12:29:34 pm »
Never heard of brazing aluminum.  Sounds more tricky than my skill supports.  Anyway, TIG or brazing would never look factory and likely worse than just leaving it broken off.
Online beanflying
« Reply #4 on: December 31, 2023, 12:51:49 pm »
Take a look through this repair I did a few years ago now on a HP 740B handle. Was done at the time with a $6 butane torch. https://www.eevblog.com/forum/testgear/hewlett-packard-740b-dc-standard-digital-voltmeter-(and-740a)/msg1419955/#msg1419955
The Key is really prep, pre and post heating. Even owning a good Tig welder I would still give this a go first with the now better Propane torch I own.
The following users thanked this post: Kean
Offline Brumby
« Reply #5 on: December 31, 2023, 01:59:02 pm »
PM sent
Offline Brumby
« Reply #6 on: December 31, 2023, 02:03:18 pm »
(You can thank Bean for this being in my possession.)
« Reply #7 on: December 31, 2023, 02:18:06 pm »
Impressive work.  I don't think I could get a repair that looked that good with sufficient penetration to retain any usable strength.  Nonetheless, I may have a replacement on the way and might try to make the repair.
Offline YU7C
  • Country: cs
« Reply #8 on: December 31, 2023, 03:24:12 pm »
I am also looking for HP handle but for 3586C.
HP pn 5061-0090
BR,
Voja
Online coromonadalix
« Last Edit: December 31, 2023, 03:39:04 pm by coromonadalix »
Offline YU7C
  • Country: cs
Online beanflying
« Reply #11 on: December 31, 2023, 05:32:58 pm »
 >:D Nice to know I could help others with you buying a "spare" Sig Gen parts donor :-DD
Offline bdunham7
« Reply #12 on: December 31, 2023, 06:34:58 pm »
Let me know if all that doesn't pan out, I have a set here that I think is correct.  I'll need to make sure I don't have an intended home for them before letting them go, but I can't think of any hulking HP projects hanging about without handles at the moment.
Offline Brumby
« Reply #13 on: December 31, 2023, 11:25:00 pm »
I knew you'd enjoy that.
I do have a set of handles as well, but they are presently attached to the operational 8656B - and I'm not inclined to part them out.  The parts unit only came with 1 handle, so I'm happy for that to find a home with a mate.
« Last Edit: December 31, 2023, 11:26:33 pm by Brumby »
Online nctnico
« Reply #14 on: January 01, 2024, 04:57:29 am »
You don't need flux when using the Bernzomatic brazing rods. Harbour freight sells similar (no flux) aluminium brazing rods which work equally well. I have used both. But it is not an easy process to master (at least with the butane torch I have). I'd recommend to grind down the edges so you end up with a 30 (2x 15) degree V shape that gets filled.
« Last Edit: January 01, 2024, 05:02:28 am by nctnico »
Re: (Found) WTB - Anyone have a spare HP side handle
« Reply #15 on: January 02, 2024, 11:36:29 pm »
Brumby has me one on the way.  Thanks guys.
