Author Topic: WTB Australia 2 of 1x / 10x 100mhz oscilloscope probes  (Read 214 times)
Offline Marck
« on: October 05, 2019, 09:07:48 am »
I have just bought my first DSO and it has no probes I am looking for a couple of reasonable 100Mhz 1x / 10x probes to start out.  I am not sure if I should be buying some cheep eBay probes or looking at a better second hand set.
Thanks
Marc
Online IconicPCB
Re: WTB Australia 2 of 1x / 10x 100mhz oscilloscope probes
« Reply #1 on: October 05, 2019, 10:37:25 am »
check out Rockby, they may have NOS Bwd probes
Offline wilfred
« Reply #2 on: October 05, 2019, 12:18:27 pm »
Rockby would be a long shot. I think I bought the last three.
Offline Marck
« Reply #3 on: October 05, 2019, 10:31:11 pm »
Thanks for the lead I checked out Rockby but no luck.
Online Shock
« Reply #4 on: October 06, 2019, 08:06:02 am »
Welcome to the forum, ideally you should get a pair that have had their bandwidth tested and the compensation range can be adjusted to match the scope. So knowing the brand of scope you have and the probes it uses may help, as well as looking through the forums to find some previous threads on ones that have been tested.
Sorry can't offer more advice than that, I have plenty of probes and never had to buy or test any.
Multimeters: Fluke 87V, 117, 27/FM
Oscilloscopes: Rigol DS1054Z, Phillips PM3065
Offline Marck
« Reply #5 on: October 06, 2019, 09:37:59 am »
The Scope is a Rigol DS1052e.  I am away for work for a couple of weeks so I will not get my hands on it until I get home.  I am looking at 100mhz probes because of the chance that I might be able to bump it up to a 100mhz.
Is there any sort of shop / specialist who deals in 2nd hand test equipment on the east coast that anyone knows of ?
Marc
Online Shock
« Reply #6 on: October 06, 2019, 03:09:27 pm »
Not that I know of sorry. Here are the two Rigol 150MHz probes that are listed for the DS1054Z (100MHz). Check the specs/compensation ranges and prices to see if suitable.
https://telonicinstruments.co.uk/rigol-uk/RP/PVP2150%20User%20Guide.pdf
https://telonicinstruments.co.uk/rigol-uk/RP/RP2200%20User%20Guide.pdf
