Author Topic: WTB: Manual Wire Wrapping Tools and Wire Wrapping Wire  (Read 456 times)
Offline ZGoodeTopic starter
  • Grad student by day, equipment nerd also by day
« on: June 15, 2024, 04:05:46 am »
Howdy,
I'm looking to get some manual tools for wire wrapping and some of the wire for it.  I don't really now where to start, or what exactly I need for this, but I have some stuff that needs repair in which this is probably the best way to go about it since that was the original manufacturing method used (probably for customization)
Offline jonpaul
Re: WTB: Manual Wire Wrapping Tools and Wire Wrapping Wire
« Reply #1 on: June 15, 2024, 05:01:33 am »
Have everything, PM me
j
Jean-Paul  the Internet Dinosaur
« Reply #2 on: June 15, 2024, 07:26:30 am »
PM sent
Online tggzzz
« Reply #3 on: June 15, 2024, 09:25:30 am »
Keywords are 30AWG Kynar silver
Offline artag
« Reply #4 on: June 15, 2024, 10:03:33 am »
Minimal tool is WSU-30M.
Price varies widely but I have had no problem with the cheaper ones, which may be clones.
https://uk.farnell.com/metcal/wsu-30m/wire-wrap-tool/dp/441089
https://www.amazon.co.uk/Function-Single-Stranded-WSU-30M-Strippers/dp/B0BKG281J8
https://www.ebay.co.uk/itm/352795434322
The 'M' stands for modified wrap. A standard wrap only puts the wire around the post. A modified wrap puts a turn of insulated wire at the end, creating a strain relief and reducing the possibility of shorts. Highly recommended.
ALWAYS strip the wire such that the strip blade is pulled tight against the tool shaft. It will snap if pulled away from the shaft.
Next step up is separate strip, wrap and unwrap tools. A lot of wire strippers can't handle the narrow slipper tefzel insulation. Get a tool made specifically for wrapping wire.  Tbh you can use the wrapping part of the WSU-30M perfectly well for a moderate number of joints and even the stripper is quite good. The unwrapper is a bit less reliable.
Next is powered wrap. A delight to use but the cut-strip-wrap bits are expensive and wear quite quickly. The electric or pneumatic tools themselves are widely available secondhand, it's the bits you'll struggle with.
Offline artag
« Reply #5 on: June 15, 2024, 10:04:19 am »
Also tefzel, an alternate to kynar insulation (or maybe just a different tradename).
