Author Topic: WTB - Noritake GU256X64-315 Custom VFD for Agilent 81101A  (Read 1562 times)
Offline switch998
« on: May 20, 2018, 02:47:27 am »
Hi Everyone! I need to buy a VFD after my 81101A suffered an impact to the screen. I'm having a really hard time finding this model, since it appears to be custom. It's used in the following Agilent products. Hopefully someone here has a spares unit kicking around.
81101A
81104A
8110A
81110A
81130A
8114A
8169A
E5574A
The part # is GU256x64-315, the VFD itself is DM256x64L. There is a newer screen, but since keysight only posts low res images on their site I can't make out the numbers. It looks like GU256x64-901D, a good way to tell is the replacement has a Xilinx Spartan FPGA onboard in lieu of the standard Itron chips.
Online nfmax
Re: WTB - Noritake GU256X64-315 Custom VFD for Agilent 81101A
« Reply #1 on: May 21, 2018, 10:57:49 am »
Me too! I have an 8110A with a very dim, but still functional display. I wonder if it would be feasible to reverse-engineer the drive protocol & use a modern LCD of some sort?
Offline digsys
    • DIGSYS
« Reply #2 on: May 21, 2018, 12:11:09 pm »
We used heaps of -GU256x64-332, GU256x64-372, GU256x64-355, GU256x64-900, GU256x64-3900 on a LXE 900MHz radio terminal -The MDT1280.
I would buy dead units from USA for ~$100-200 and rip the VFDs out of them. I do recall the GU256x64-315, but I'd have to get to my shipping
container to see if there's anything left. You can check out LXE1280, 1290, 2280, 2285 to find out if any models used that exact part.
I have the pdfs for the models I quoted above, but would have to do a search through archives for the -315.
They were used a lot in radio terminals, hopefully, that may help. If you get stuck, I can do the big search :-)
Actually, at one point, I did make an interface so that I could run all the new LCDs, but again, long time ago. The code wasn't that hard to reverse.
Online nfmax
« Reply #3 on: May 21, 2018, 06:39:17 pm »
Any idea what the model number differences are about? Simple stuff like mounting holes/connectors or a completely different interface? I had no luck hunting down a replacement and currently make do with what I have.
Offline digsys
    • DIGSYS
« Reply #4 on: May 22, 2018, 12:23:34 am »
Quote from: nfmax
All the above :-) (unfortunately) I've posted the data manuals for what I could "easily" find at -
www.digsys.com.au/ftp/GU256x64-332.pdf   www.digsys.com.au/ftp/GU256x64-355.pdf   www.digsys.com.au/ftp/GU256x64-372.pdf
www.digsys.com.au/ftp/GU256x64-900.pdf   www.digsys.com.au/ftp/GU256x64f-3900.pdf
I do remember the -315 version, but it'll take me a few days (maybe less) to find it.
Offline switch998
« Reply #5 on: May 22, 2018, 03:58:39 am »
Thanks for the info, keep me posted if you find a -315. I'll take a look at some of those radios, hopefully I can hack something together if there isn't a direct replacement. There must be some other product that is using the same display though.
I just received a -352 the other day, which should work, however the VFD is twice as large as the original.... it looked to scale in the photos, but of course I got lazy and didn't check it. It's so frustrating that they built in a custom module  |O
« Last Edit: May 22, 2018, 04:12:51 am by switch998 »
Offline JosiahCochran
« Reply #6 on: September 19, 2019, 06:30:54 pm »
Hey any luck on this? Anyone happen to have decoded the data lines and hooked up an lcd, or have data sheets for the 315 or the main chip on there? I can’t find a datasheet anywhere for the ma621468. Is that a micro or a dedicated VFD driver?
Offline digsys
    • DIGSYS
« Reply #7 on: September 21, 2019, 09:39:34 am »
Totally forgot all about this .. old age :-)
I'm currently on the World solar challenge run, back in a couple weeks. This post will act as a bookmark, so I don't forget again :-)
Online nfmax
« Reply #8 on: January 10, 2020, 05:20:02 pm »
I hope the solar challenge went well - and have you had any luck finding the displays?
Offline little.tesla
« Reply #9 on: January 11, 2020, 12:17:08 pm »
Any news on the datasheet or possible replacement for this display?
Offline digsys
    • DIGSYS
« Reply #10 on: January 11, 2020, 12:24:26 pm »
ooooops sorry ... totally forgot about this :-)  Promise to look for the data tomorrow - near midnight here now
The following users thanked this post: nfmax, little.tesla
Offline digsys
    • DIGSYS
« Reply #11 on: January 12, 2020, 09:53:31 am »
Thanks, Solar challenge is always fun - HEAPS of incidents this year :-)
OK searched pretty much everything that is easy to get to, with no more than I posted before. I've had massive giveaways / e-wastes over the last years, possibly in one of the boxes of stuff.
Sorry - but in a coincidental event last week, I received an "extension" order for the original project (after 2-3 yrs idle). I should be visiting my storage containers on site in the next few weeks. There is a small possibility that there may be a few / several of the original MDTs in it. At one stage I had 2+ containers full of e-waste (obsolete radio / terminal / DGPS / RFId etc etc) They do occasionally take away skip fulls, but it is a very poorly organized. A glimmer :-)
I've marked it down this time, so I won't forget :-)
Offline digsys
    • DIGSYS
« Reply #12 on: January 21, 2020, 09:01:36 am »
Hi guys, a bit late back, but have some results -
Searched 2 of our yard storage containers, but no luck. Found heaps of their replacement terminals - a Thor / Honeywell VM3, but that has a full size LCD.
I will be back there again in the next week or two, and have got permission to search the containers way down the back of the yard.
I was informed that a few skips of e-waste have been emptied, so could be slim. I've also asked the other states to check their old piles (item is a LXE MDT1280).
Sorry I don't have better news. 20-30 yrs back, we had 100s of the suckers.
Online nfmax
« Reply #13 on: January 21, 2020, 09:52:09 am »
Many thanks for following this up for us! Even if you dont have any displays, is there any chance of documentation on their interface, to help design a replacement? Maybe the source code of your terminals would have something?
Offline digsys
    • DIGSYS
« Reply #14 on: January 21, 2020, 10:24:04 am »
That I can do. It'll take a few days to dig out the old backups, but I do keep ALL files / programs from year dot.
