Author Topic: WTB: Programmed EEPROM for HP3632A power supply  (Read 548 times)
Offline justasonTopic starter
« on: March 25, 2024, 09:07:33 am »
For reparing of HP3632A power supply Im looking for programmed AM27C020-150JC PLCC32 EEPROM
Binary file could be found in this thread:
https://www.eevblog.com/forum/repair/hp-e3632a-firmware/msg3092802/#msg3092802
Offline testpoint1
Re: WTB: Programmed EEPROM for HP3632A power supply
« Reply #1 on: March 25, 2024, 03:24:46 pm »
that is ST M27C2001 PLCC32
Offline bingo600
« Reply #2 on: March 25, 2024, 05:09:36 pm »
« Reply #3 on: March 26, 2024, 06:39:50 am »
Thanks,
yet, it is AM27C020-150JC, however the ST M27C2001 PLCC32 could be a replacement for it.
I do not have EEPROM programmer which supports that type of EEPROM - so I'm looking to buy:
- ready programmed chip.
or
- buy a chip and send it for programming.
Details in PM.
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
« Reply #4 on: March 26, 2024, 07:52:43 am »
I do chip programming about 60% of my business right now my equipment supports it. If You buy the chips (Drop Ship) and provide postage form the USA to You ill burn one for ya.
The Only issue with it is finding a reliable source for these older chips that are real and/or actually blank. Maybe a AT29C020 256X8 flash could work you would need to look at the data sheet.
Some of my clients will only buy the UV or Flash variants if compatible now days due to the poor one time programmable market selling used as new.
« Last Edit: March 26, 2024, 08:09:06 am by KG7AMV »
« Reply #5 on: March 27, 2024, 06:41:06 am »
Thanks for the info,
Let's switch to PM.
