PedroDaGr8 is almost correct.
Whilst aluminium is a good conductor, it easily forms a highly non conductive aluminium oxide skin when exposed to air.
When I worked in the power industry, aluminum cables and conductor ends were always cleaned (shiny) prior to joining (usually by a crimped or bolted connection) and then treated with Alcoa No 3 paste (If I remember correctly).
However is your problem more basic than this?
If you have a connector system ( I said system) from a manufacturer, and they rate it for a certain current, irrespective of the materials used, the connector should carry the current to it's ratings.
I'd go back to the manufacturer and ask why it does not perform to their specifications. That's what the field sales people are for (and you thought they were there just to annoy you).
Robert
The connectors are rated to 28A, and I'd expect a cable with that rating to have overhead to 30A, and handle peaks of up to 32-36A.
Instead, they're failing at 24-28A. The problem we have is that our specification is simply for a cable rated to 28A, with x dimensions using this style connector. Our Taipei team passes that spec to the PSU vendor, who pass that spec to their cable vendor, who then purchase the connectors from their vendors. It's way up the supply chain, and we didn't specify x materials. So it's basically been uncontrolled.
The problem could as well be that the cable vendor or the connector vendor are skimping; but I don't have evidence of that. What I do have is evidence that aluminum sucks for our application. So by nailing down a specification on what metal is to be used, we'll also be able to force the cable and PSU vendors to perform basic QA to make sure the connector is meeting that spec; and they should therefore also catch any other skimping that would prevent the connector from handling a constant 28A. Plus if the problem is deformation and galvanic corrosion (which does seem reasonably likely), that problem will be fixed.
It really is the cable vendor who should be handling this; but because they're handling it extremely slowly, with little transparency, and in Chinese, I did my own investigation.
