Author Topic: HOLY SMOKE !? - Now I have a button - SAFETY in a EE bench  (Read 934 times)
Offline Zucca
  • EE meid in Itali
« on: September 29, 2018, 08:15:44 am »
Designed to power off the entire bench by disconnecting a relais. User the toner transfer method for the first time... not bad but a lot of work. I will use in the future sticker paper.
I like it.
What you guys have as "safety" on your bench beside brain?
PS: I was shocked to discover that Solidworks has not a mirrored Text option... at least in sketch. I had to do the text with pussy power point.
« Last Edit: September 29, 2018, 08:19:28 am by zucca »
Offline German_EE
Re: HOLY SMOKE !? - Now I have a button - SAFETY in a EE bench
« Reply #1 on: September 29, 2018, 08:25:55 am »
I have an RCD at one end of the bench and everyone knows to press the yellow 'test' button in case of trouble. That kills everything.
Warren Buffett
Offline onesixright
« Reply #2 on: September 29, 2018, 08:27:22 am »
// OT
Love the Metcals [emoji41]
Sent from my X using Tapatalk
Offline GreyWoolfe
  • NW0LF
« Reply #3 on: September 29, 2018, 12:46:44 pm »
// OT
