Author Topic: (Fake) RKC Rex-C100 - Can I change the sensor type?  (Read 546 times)
Offline Yellofriend
  • Country: hk
« on: April 05, 2018, 01:55:33 am »
I got a cheap RKC Rex-C100 from Taobao a while ago. It's obviously fake and will lack some function of the original.
Anyway, I am using a K-type Thermocouple and that is off by about 4°C. My usage range will be 30-55°C, and that is already wide.
A few question:
  • Can the sensor type changed? Mine seems for K type, can it change to PT100?
  • Can the K type range be set? The standard is 0-200°C (K01), but I see also a 0-100°C setting (K13). Or is that hard wired to the C100?
  • Can the tolerance be adjusted?
I might just re-adjust to the wrong °C, but this silly timewasting drive for perfection....
TVM802C with 2.23Beta2
T962A
