Author Topic: [YouTube] 8-bit Guy epic fail  (Read 8709 times)
Offline WenkXue
« on: May 03, 2017, 09:40:41 pm »
So this guy tried to use an Apple charger to power on the display.
Waaa.....
I think the floating ground of his Apple charger fried his computer.
Is that right, guys?
« Last Edit: May 03, 2017, 09:42:24 pm by WenkXue »
Offline ataradov
    • Personal site
Re: [YouTube] 8-bit Guy epic fail
« Reply #1 on: May 03, 2017, 09:53:26 pm »
Looks like just a faulty power supply. What it has to do with its ground floating?
Alex
Offline Ampera
    • Ampera's Forums
« Reply #2 on: May 03, 2017, 10:04:49 pm »
Alright then.
C/C++/Java Programmer, Legacy hardware enthusiast, madman.
If it's broken, I probably did it.
EEVBlog IRC: irc.austnet.irc #eevblog
Offline helius
« Reply #3 on: May 03, 2017, 10:16:51 pm »
Most switchers are smart enough to know that they have failed and disable the output. The 7805 in the C64's supply isn't and that is a common failure: the pass transistor gets shorted leaving the output unregulated.
Offline MarkS
« Reply #4 on: May 03, 2017, 10:28:10 pm »
Yes. Watch the video fully before criticizing someone. ;)
Offline FrankBuss
    • Frank Buss
« Reply #5 on: May 03, 2017, 10:29:29 pm »
Interesting that this 8 bit guy has as many Youtube subscribers as EEVblog, nearly half a million. BTW, this is the first part for the display:
Very basic content and boring for me, but still 200k views and 18k likes :o? I could do this, too, but unfortunately everyone would complain about my German accent, and I'm not good on camera. Ok, so maybe I couldn't do it :)
Offline ataradov
    • Personal site
« Reply #6 on: May 03, 2017, 10:31:50 pm »
This specific video (both of them) are very much offtopic for the channel. The rest of the videos are pretty entertaining to me personally. He also has 8-Bit Keys channel, all about old sound making devices.
Alex
Offline helius
« Reply #7 on: May 03, 2017, 10:34:42 pm »
You can definitely succeed on YouTube with a heavy German accent, like Flula Borg:
9 million views
Offline MarkS
« Reply #8 on: May 03, 2017, 10:35:33 pm »
I would classify this video series as being targeted towards beginners.
Offline FrankBuss
    • Frank Buss
« Reply #9 on: May 03, 2017, 10:46:32 pm »
9 million views
OMG, I guess I can't make such very stupid videos, so I will never get that much views :)
Right, I watched some other videos, very good quality with interviews (like in "The basics of BASIC", interviewing Ben Heck), good video editing, lots of content and good explanations. Of course, still boring for me, because I know most of this stuff already as an old C64 assembler programmer, but I subscribed to the channel now.
Offline Ampera
    • Ampera's Forums
« Reply #10 on: May 03, 2017, 11:02:40 pm »
Okay, so I watched both videos, and I have no clue what the hell he is talking about. The OP somehow seems to think that the power from the LCD was frying the computer?
Personally I have watched The 8-Bit Guy since he was called the iBook Guy (Ironically one of the first videos he put out after he switched names was about an iBook/MacBook) and I am kinda impressed at how well he understands electronics. Not sure why I thought he didn't understand it, I might be confusing him with Techmoan a bit.
Even an uneducated fool like me can understand what happened in that video, and I see no way the LCD could have fried the C64. Even if power somehow leaked into the data pins, it's 5v, there is no way it could have fried anything, and if the ground was floating when the ground wire came loose, there shouldn't really have been any power doing much of anything on the screen.
So, as mentioned,
I think this may have something to do with this.
Offline WenkXue
« Reply #11 on: May 03, 2017, 11:13:10 pm »
Because the Apple charger has only two leads, it's not grounded, it may be possible that there is a great voltage potential between two power supplies.
Remember that Commadore worked fine before he attached the LCD with the Apple charger, you are telling me that a power supply just suddenly failed for natural causes?
Got flamed for posting for the first time, wow.
« Last Edit: May 03, 2017, 11:15:44 pm by WenkXue »
Offline ataradov
    • Personal site
« Reply #12 on: May 03, 2017, 11:21:59 pm »
Both supplies would be isolated. Yes, their grounds will be totally independent, but it is not the reason for a failure like that.
That lose ground wire may have shorted something, while it was lose, of course. So I don't think it was "natural", it was definitely due to connecting some random stuff to the computer, but I doubt it has anything to do with grounds.
Alex
Offline HoracioDos
  • Country: ar
  • Just an IT monkey with a DSO
« Reply #13 on: May 03, 2017, 11:29:03 pm »
I will follow you. Go ahead! As a spanish speaker, we are used to watch almost everything in other languages (with or without accents)
Offline MarkS
« Reply #14 on: May 03, 2017, 11:30:16 pm »
You got flamed for posting misinformation and slighting someone that actually knows what they are doing and did nothing wrong. If you had watched the whole video, you would have seen him find the source of the problem and correct it. You either ignored that part of the video and posted what you did here because you have a problem with him or you stopped the video shortly after the point where you thought you saw the error and posted here. Either way, we're not going to put up with that. That was your first post and not a particularly good start at that.
Offline Ampera
    • Ampera's Forums
« Reply #15 on: May 03, 2017, 11:49:53 pm »
A. Power supplies are isolated
B. Even if there was leakage, it's 5v either end
C. If this is the cause, it should be repeatable. He used another computer with an identical setup and it worked fine.
D. It started before he hooked the LCDs up. He stated a voice synth module he was using even before all of this fried. This suggests that the power supply was sending spikes of current into the Commodore, enough to fry some stuff, but maybe not the actual computer until it did. There is no proof nor evidence to suggest that the separate power supplies and the floating ground had anything to do with the power supply failing. The power supply is completely separate, and unless there was some random surge of current from the Apple charger that went through whatever isolation was on the LCD, through the C64 without breaking it, and into the power supply, I see 0 reason why the LCD had anything to do with it, and as previously mentioned, this doesn't account for the busted voice synth cart.
And the reason I pointed out the first post thing is that it's normally quite odd for someone to hop on the forum for the first time, complain about somebody, and leave little else. I apologize if you are a genuine first poster, and in that event, welcome to the forum, but we do occasionally get people joining the forum to rank on someone for some reason. I've seen it happen.
Offline WenkXue
« Reply #16 on: May 04, 2017, 12:17:22 am »
1.Oh my god, it's not 5V either end, a floating power supply could have tens or over a hundred volts floating upon contact with another power supply if the two power supply are isolated for some time.
2.He used a newer model on the second try, it may have some bleed mechanism to deal with the floating voltage, or he connected the LCD before connecting the Apple charger, which could also solve the floating problem.
3.Have you ever disconnected the metal bridge connecting the (-) and (Gnd) on your power supply and powered multiple devices with multiple isolated power supplies? Please try and probe those devices differentially, you will understand what I am saying.
Offline MarkS
« Reply #17 on: May 04, 2017, 12:25:20 am »
Regardless, you still did not pay attention to the video. He fried the first LCD by connecting its power connectors directly to the C64's port. By this time, the C64's power supply was already spiking and that killed the LCD. Not knowing this at the time, he then hooked up a second and then third LCD and used a secondary supply for these LCDs. This still had trouble, which led him to investigate further. It was during this investigation that he found the C64's power supply was damaged. The secondary supply was not the source of the problems he showed in the video. At worst, the secondary supply would have fried the third LCD; it did not.
You are attacking someone that did nothing wrong. Get over it and move along. Post something productive.
« Last Edit: May 04, 2017, 12:27:47 am by MarkS »
Offline FrankBuss
    • Frank Buss
« Reply #18 on: May 04, 2017, 12:35:21 am »
He didn't follow Dave's first commandment early enough: Thou shall check voltages!
Offline MarkS
« Reply #19 on: May 04, 2017, 12:37:28 am »
True, but the C64 runs off of 5 volts and it was operating normally at the time. He had no reason to doubt it. Lesson learned, I guess.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #20 on: May 04, 2017, 12:55:51 am »
Problem with a lot of online video journals is they are -made by - users - not developers/techs.
They often have little or no idea of how the technology works or connects together - beyond the plugs described in the user manual.
That's why we're here!
Don't ask a question if you aren't willing to listen to the answer.
Online CJay
  • M0UAW
« Reply #21 on: May 04, 2017, 09:54:54 am »
Yebbut, after the first failure...
Those PSUs are horrible and even back in the day they caused loads of problems, the first check whenever a C64 came for repair was the PSU voltages, casualties were usually the 906114 and/or the RAM.
Hope he's learned a lesson, those chips aren't getting any easier to find
M0UAW
Offline tooki
« Reply #22 on: May 08, 2017, 01:30:42 pm »
The electronics YouTuber "GreatScott" is German but makes his videos in English, and they are great even with the accent! (I wish he'd spend more time on-camera... he's hot! 0:) )
« Reply #23 on: May 08, 2017, 04:24:06 pm »
I had a computer that had a failure of the 5V regulator, which then proceeded to put the full 16V unregulated rail into the computer for a few hours. It still worked fine, did all it was required to do but just had some odd behaviour, the self test never ran. Took the cover off, started checking power supply voltages on the test points. Start as usual from the bottom, -21V ok, -19V ok, -15V ok, -12V ok, 15V ok, then go to the 5V rail, and the meter did a range switch more than expected, I was expecting it to range from 1V to 10V, but it did 2 relay clicks. Shlumberger rack mounted meter, dating from the 1970's, and very loud relays ( but a lovely meter), and it was showing 16VDC on the 5V rail, not the expevted 5V1 or so it should be showing.
Power off, and spent a while changing all the parts in the %v regulator circuit, from the pass transistors to the zener reference, including all the resistors, and the SCR crowbar that was not exactly working. then power up, 5v back to 5V, and it still had that odd power on self test issue. Go card hunting, and eventually saw the rather obvious failed IC, a SFC5403PM3 IC, which had delidded itself. Ironically, the 30V rated open collector IC was the only thing that failed running off 16V. New card, and it was fine again.
Yes it did run the TTL off a 16V supply, cooking off the power in a massive heatsink block and the chassis, using a pair of beefy power transistors as pass elements, and this worked well.
The other computer used a 28V supply, and had 2 SMPS units in it, one providing a constant 5V supply, using some BUX20 transistors as switches, and an air core inductor as buck inductance. Each supply was identical, just the one was switched off most of the time, being enabled only at the peak of the reference phase 400Hz to power the arithmetic logic, then being turned off to both save power and keep the computer power use under 500W, important in a shoe box that had over 5000 TTL IC's in it.
Offline Zero999
  • 0999
« Reply #24 on: May 08, 2017, 06:45:50 pm »
Yes, the output even read close to 5V, when the IO pins were set to high.
Actually could that have been a warning sign? Wouldn't 3.4V have been expected, rather than 5V, assuming it has a TTL output?
Perhaps one of his next project could be an over-voltage crowbar? It doesn't need to be complicated. A thyristor plus the TL431 would do the trick.
