Author Topic: 10 MHz Everywhere!  (Read 8026 times)
Online xrunnerTopic starter
  • hp>Agilent>Keysight>???
10 MHz Everywhere!
« on: April 07, 2017, 06:36:11 pm »
TheSteve started this ...
10 MHz everywhere!
It does seem to be everywhere TheSteve, it's at my house too. In fact it's all over the place here.
Is it at anyone else's house?
Offline slurry
Re: 10 MHz Everywhere!
« Reply #1 on: April 07, 2017, 06:43:04 pm »
It's in my house too, strange... hmmm...  :D
I run a FE-xxxx Rubidium and usually a re-purposed video distribution amplifier but now a BG7TBL distribution amplifier is used, i'm not really a time-nut so i keep it simple...for now  ^-^
Offline TheSteve
  • Living the Dream
« Reply #2 on: April 07, 2017, 06:59:18 pm »
10 MHz everywhere!
Clearly my distribution amplifier is working extremely well.
VE7FM
Offline JPortici
« Reply #3 on: April 07, 2017, 08:45:34 pm »
I don't trust that 10.000000 (muhuahahaha)
« Reply #4 on: April 07, 2017, 10:14:36 pm »
Oh man, now I can't believe you don't trust that.  :)
How can I convince you?  :popcorn:
Offline Brumby
« Reply #5 on: April 08, 2017, 03:25:18 am »
That is an elegant piece of gear.
Offline awallin
« Reply #6 on: April 08, 2017, 08:44:44 am »
Don't turn it on - take it apart  :-/O
Offline Brumby
« Reply #7 on: April 08, 2017, 08:51:33 am »
If you must .... but DON'T scratch the case!
Offline DimitriP
« Reply #8 on: April 08, 2017, 09:58:31 am »
Add more 000 :)
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #9 on: April 08, 2017, 11:16:24 am »
Meh, time-nuts... I don't even monitor my Rb...  :palm:
« Reply #10 on: April 08, 2017, 03:12:12 pm »
Add more 000 :)
Hehehe - How many? I'll never be able to add enough to satisfy you - I know how this game goes.  8)
Offline tszaboo
« Reply #11 on: April 08, 2017, 04:48:39 pm »
So, that means, if you connect the 10 MHz on the front, and on the back of a timer counter, than it will be 10 MHz on the screen?  :-DD
Offline PA0PBZ
« Reply #12 on: April 08, 2017, 05:01:54 pm »
Let me tell you a little secret: It doesn't even have to be 10 MHz  8)
Offline TheSteve
  • Living the Dream
« Reply #13 on: April 08, 2017, 05:14:10 pm »
Already done! I had to see the inside.
VE7FM
Offline bingo600
« Reply #14 on: April 08, 2017, 05:40:54 pm »
That's not an "Everywhere Box"   :-//
This is an "Everywhere Box"   ;) ;)   - 8 x 5 (40) outputs  - I got mine from KJDS
https://www.eevblog.com/forum/testgear/fun-with-a-racal-9480-with-ocxo-40-10mhz-outputs-(8x-5-chan)/msg653659/#msg653659
http://www.ebay.com/itm/Racal-9480-10-04B-Time-and-frequency-mainframe-/401010554495
Congrats Steve - I bet it has nice specs.
/Bingo
« Last Edit: April 08, 2017, 05:42:47 pm by bingo600 »
Offline TheSteve
  • Living the Dream
« Reply #15 on: April 08, 2017, 05:46:07 pm »
It does look pretty - but does yours accept two inputs and auto fail over to the backup input, while also accepting alarm inputs and generating alarm outputs?  :)
VE7FM
Offline bingo600
« Reply #16 on: April 08, 2017, 05:54:36 pm »
It actually have a built-in ocxo (or RB) , that it switches to.
If the primary input fails (is undetected)
And it has alarms etc too ...   , yours seems like it's a "next gen" dist-amp though.
I got it because i ran out of chans. on my old distamp , now i have enough
/Bingo
« Last Edit: April 08, 2017, 05:56:21 pm by bingo600 »
Offline TheSteve
  • Living the Dream
« Reply #17 on: April 08, 2017, 06:06:41 pm »
Mine is still from the HP era of course. I did some basic testing and its performance seems better then anything I own can measure.
It can have an OCXO fitted internally and will fail to it. I will see if I can get some good pics later. It does seem rather entertaining that a 10 MHz distribution amp would have firmware, a processor, ram, and it communicate via SCPI. I admit I have lusted after one for quite some time, I've made several lowball best offers on them over the last year or two. One was finally accepted.
VE7FM
Offline Red Squirrel
« Reply #18 on: April 08, 2017, 09:04:29 pm »
Need one of these too now:
http://www.ebay.ca/itm/Symmetricom-OT-21-Officetime-Multiplexer-25413150-411-0-/272452367547?hash=item3f6f6d34bb:g:QAwAAOSwcLxYLOIz
And GPS antenna.
That's a different kind of "clock" though.  :P  Those GPS antennas also double as lightning rod, my coworker who was in our building when it got hit knows all about that.  :-DD
I don't know too much about this stuff, just that it's used to sync up communication stuff, but I think they also have an NTP server built in.  Why use time.gov as a time source when you can be your own time source!
« Last Edit: April 08, 2017, 09:06:44 pm by Red Squirrel »
Offline TheSteve
  • Living the Dream
« Reply #19 on: April 11, 2017, 04:38:07 am »
The 58502A got its own shelf.
Seems to be bang on....  >:D
« Last Edit: April 11, 2017, 05:49:21 am by TheSteve »
VE7FM
Offline tszaboo
« Reply #20 on: April 11, 2017, 09:22:18 am »
I dont understand time nuts. They can create voltage references, or very accurate currents, but they waste their time on time... :-//
 ;D
Offline Berni
  • Country: si
« Reply #21 on: April 11, 2017, 01:01:53 pm »
 ;D
Well at least its a slightly easier hobby than being a volt nut. You can use GPS clocks to verify long term drift of your oscillators. No such thing for checking if your HP 3458A is drifting.
Offline Harb
« Reply #22 on: April 11, 2017, 01:08:22 pm »
I just use a big VDA....I think it has 100 or so outputs.....10 on each euro card.
Offline edpalmer42
« Reply #23 on: April 11, 2017, 04:52:10 pm »
One 'trap for young players' when you convert a 75 ohm Video Distribution Amp to 50 ohms is total load.  I use a VDA that uses an Analog Devices amplifier.  It can handle 8 75 ohm outputs but only 5 50 ohm outputs.  It's not a big problem because you can daisy chain multiple inputs together.  But it's something to keep in mind.
Ed
Offline TheSteve
  • Living the Dream
« Reply #24 on: April 11, 2017, 05:38:49 pm »
I used a modified VDA previously and the output quality was crap. Obviously they vary in quality like everything else, the one I chose was clearly junk.
« Last Edit: April 12, 2017, 02:38:06 am by TheSteve »
VE7FM
