Author Topic: 100% touchscreen nuke control room - improvement or abomination?  (Read 4413 times)
Offline Nauris
Re: 100% touchscreen nuke control room - improvement or abomination?
« Reply #25 on: August 17, 2021, 08:23:18 am »
m98 - Where are those plants located - in Germany?  When were they built?
Apperently they are
1. Nuscale
2. Yangjiang Nuclear Power Plant with chinese digital control (2018)
3. Akademik Lomonosov the floating russian 2x32 MW power plant build in 2010
4. Control room for ArcelorMittal Bremen steel plant energy distribution (2019)
Offline AlbertLTopic starter
« Reply #26 on: August 17, 2021, 12:40:28 pm »
Because no new nuclear plants are being built in the US, I expect that the Nuclear Regulatory Commission will never be asked to approve a touchscreen control room, simply due to the absence of any requests to do so.  Whether they would approve one if requested, and what investigations they would make in the process, is an interesting question.  Note that the room in the original post is a simulator of a simulator; the "official" simulator is required to be a precise replica of the operational control room.
Offline Ground_Loop
« Reply #27 on: August 17, 2021, 04:04:17 pm »
I spent a few years running nuclear reactors that had no digital controls, not even a seven segment display.  In fact, the only integrated circuits I knew of were in the square root calculators for steam flow, but they were analog as well.  Anyway, I always though a digital display system would be really helpful, but only for display.  The control inputs should remain actual hardware devices.  Touch screen inputs for something like changing views would be ok.  But I can't imagine adjusting rod height or switching pumps with a screen icon.  The big switch is mandatory, especially during a startup.
« Last Edit: August 17, 2021, 04:37:20 pm by Ground_Loop »
There's no point getting old if you don't have stories.
Offline djacobow
  • takin' it apart since the 70's
« Reply #28 on: August 17, 2021, 04:12:50 pm »
Aren't touchscreens common in modern aircraft? The important controls still use physical knobs and switches, however.
I think the fancier new panels in a lot of GA aircraft have touch-screen capabilities, but there are usually other controls (buttons, knobs) that access all the main functions. And the very most important of those are single-modal.
On airliners, I don't think there's much touch screens, but I could be wrong. For example, FMSs, which would be a natural place for a touch screen, almost universally have keypads. So do radio controls, etc.
Having flown some GA aircraft with touch-screen panels, I have to say I prefer knobs and buttons, particularly in turb.
Offline Bud
« Reply #29 on: August 17, 2021, 05:10:23 pm »
Apperently they are
1. Nuscale
I do not see anybody touching the screens. Instead on each of the  photos keyboards, joysticks, mice and knobs can be seen.
Offline SiliconWizard
« Reply #30 on: August 17, 2021, 05:12:42 pm »
I don't think so either. And anyway there are always physicak knobs and buttons for everything. There are touchscreens for non-critical control of the cabin though. (Lighting, media stuff, etc.)
The real exception I've seen so far in an "aircraft", if you can call it that, is in SpaceX's Crew Dragon. Oh, and astronauts have to operate that with gloves.
https://www.cnet.com/news/nasa-and-spacex-are-about-to-fly-into-space-with-a-touchscreen-demo-2-crew-dragon/
Offline Red Squirrel
« Reply #31 on: August 18, 2021, 03:02:43 am »
I can't see this being intuitive at all.  I hate that cars seem to be going towards touch for everything too.
When pressing a button I want to physically touch something, and feel a click or clunk and know that the action went through.  Touch screens just don't provide that feedback.   And what if you need to put your hand on a lever or button while looking at another screen then activate it.  You can't really do that with a touch screen.   I don't know enough about day to day operations at a nuclear control room so maybe it's ok but I feel a lot of people working at one would not like this.
Touch is also slow, since software has to process everything, while a physical button is physically activating a circuit.  Imagine trying to sync two turbines together on the grid using touch.  :o  There is going to be latency is displaying the synchroscope output, and then latency in actually processing when you "press" the button. It's also hard to kind of have your finger ready without accidentally touching it.
I bet the first time someone accidentally snaps a 2 foot thick turbine shaft they're going to rethink all of this.
I never thought of this but can bugs activate touch screens?  Going to be a bad day if ever a large bee or other bug gets in that room and lands on the screen lol.
« Last Edit: August 18, 2021, 03:04:36 am by Red Squirrel »
Offline AntiProtonBoy
  • I think I passed the Voight-Kampff test.
« Reply #32 on: August 18, 2021, 04:00:49 am »
Yeah not a fan either. Tactile interfaces are much safer to interact with, whereas with touch screens you have to shift focus, and they are very easy to screw up by pressing the wrong thing.
Offline NiHaoMike
    • Facebook Page
« Reply #33 on: August 18, 2021, 04:13:54 am »
Any reason that wouldn't be automated? At the least, it would be trivial to reject attempts to connect out of sync.
Offline cgroen
    • Carstens personal web
« Reply #34 on: August 18, 2021, 08:46:49 am »
At least touchscreens works for some....
Online coppercone2
« Reply #35 on: August 18, 2021, 09:01:17 pm »
I got to the bottom of this shit, the problem you see is that the switch manufacturers after the fall of the USSR all got bought out by a few companies to keep legacy production up but it did not help the price. They need to keep that going, CNC machines make molds cheaper, cheap molds make bakalite cheaper, so the switches should be cheaper, they are easier to make now. The main factor is probobly dealing with the little brass contacts and rivets and shit (keystone products, aka precision stampings), it is too non standard for any random shop to say 'we are building high reliability switches now". They can build everything but the contacts cheap (small hurdle to overcome). A smart switch designer program would keep these switches around IMO, so you can select pole/throw count, give it physical dimensions, and have it make a switch.
Personally for reliability I think its non sense, a nuclear power plant is the last thing you want these in. Everything else is big and heavy and going to be around for many years and nothing gets changed quick.
Can you beat a brass shaft reliability with multilayer ceramic liquid crystal LED doped glass ? So long you orient PCB sideways a wafer switch will likely operate if you spray the technician down with a large hose while he is working. touch screen a drop of water makes it act all funny already. My refrigerator is heavy on this stuff, moisture on the bottom drawer that has some kind of fancy recessed touch temperature control shit already made the whole refrigerator act funny (it was effecting the ice machine that is 3 feet away and supposedly controlled by other items!)
IMO the whole argument with 'aviation is going this way' is bullshit, aviation only cares about weight. Unless the nuclear reactor is flying there is no reason for it. And last I heard those touch screen modernization to fighters are not as good as originally thought, particularly for EMP survival. Is it going to work any better once its a little shot up ??? You keep raising impedance on highly important controls till the whole thing works like a electrometer  :scared:... thats great for not blowing up the neighborhood. And thats just the electrical part. The other part is glass.. do you really trust glass? most stuff that relies on glass has it like either 5 inches thick or reinforces it with wire... its for corporate accounting.. absolute maximum voltage : 0.5V, energy needed to trigger.. 0.3fA
A transformer (or chemical battery) connected to a mechanical switch connected to a relay is just not even in the same planet as this stuff in terms of reliability
How much I love touch screen controls.. my oven decided to turn the burners on at 10pm once by itself to highest level, greeting me with glowing disks (old IR range,switched to induction now). honeywell air purifier with touch buttons once kept going on highest settings by itself until unplugged and plugged back in. give me my fucking switches back before you kill me with electrostatic sensors .............. >:(
For a training system, I don't know. I don't think so. I think if you had a real panel you can do the improtant training of showing people how good switches sound and feel and how partially worn switches sound and feel and what a bad switch is. You train a buncha people on paper (basically you can print out paper, have people on camera watch who touches the paper and have them turn on lights), they will have no idea what a fucked up un maintained panel feels or looks like.. so its not much different then having them read a book. Once you are working that thing the slightest difference in pressure or change in sound will tell you something is off.. not to mention tactile learning is way better.. you can turn the thing off even if you are temporarily blinded (ok this is maybe more of an issue for a pilot that got a chunk of hot fragmentation from a missile delivered into his eyeball).. and you are less likely to make a mistake because you have strong physical assosiates with operating the panel that serve as memory reminders and are conducive to mental refocus in a stressful situation.. i.e. if you know there are 5 switches in a row that require heavy force, and you make it a habit of gracefully sliding a finger over to count the switches (even while you are looking at it, you feel the count), it refocuses you to the procedure you are attempting.
IMO a simple test is, get severely drunk, try to run something, the easier it is to run the better the UI is, for safety things. its a decent simulator of bewildering confusing stress that occurs in people sometimes
« Last Edit: August 18, 2021, 09:33:50 pm by coppercone2 »
Offline johnboxall
  • You do nothing, you get nothing.
« Reply #36 on: August 19, 2021, 03:40:03 am »
AFAIK nobody does car* braking by wire, so why do they think this is a good idea?
*Trailers sometimes.
Alfa Romeo Giulia.
I'm also in the anti-touchscreen club. After a few months ownership, I can use muscle memory to adjust the HVAC, stereo, headlight angle etc. in our car - without looking away from the road. No way I can do that at 110 km/h with a touch screen.
Offline jmelson
« Reply #37 on: August 19, 2021, 03:29:02 pm »
Abomination?  It is a TRAINING simulator!  You can't turn newbies loose on a live reactor (see Chernobyl to find out why) so you really need life-like simulators.
This one is really visually good, compared to some.  A complex system I have some experiece with is the ion accelerator at the National Superconducting Cyclotron Lab at MSU.  They went from pretty much a steam gauge console covered with meters and dials to all LCD screens over a period of 20 years or so.  But, the graphical representation of what was going on got SO MUCH better, it was a great help to outsiders, and must have been to the operators as well.  Then, they remoted everything, so an operator could crawl into the beamlines with a laptop, bring live camera views up on his screen, and operate valves, shutters and viewers while right next to the components involved.  I was REALLY impressed!
Jon
« Reply #38 on: August 19, 2021, 04:50:18 pm »
I think these are the kind of high-quality switches used in nuclear control rooms: https://www.electroswitch.com/products/utility-power-switches-relays/manual-standard-instrument-and-control-switches.  I'd trust these way more than any touch screen and all the software/firmware behind it.
Online David Hess
  • DavidH
« Reply #39 on: August 19, 2021, 05:15:10 pm »
Another disadvantage is that if manual physicals controls are included as backup controls to make up for unreliable touch screen controls, then when the backup controls are needed, they are less likely to work because they are not regularly used.  They will be tested less and the operators will be less familiar with them.
Offline Nusa
« Reply #40 on: August 19, 2021, 05:55:56 pm »
There's an obvious collection of manual buttons below the screens for critical/frequently used functions. Each occupant also has controls on their chair armrest for communications and maybe other things. Presumably those screens and touch panels will work in vacuum as well.
Offline Nusa
« Reply #41 on: August 19, 2021, 06:01:29 pm »
One thing that's pretty funny - at 1:24 in the video, there's a screen showing ancient electromechanical protective relays and watthour meters.  Imagine programming for a simulation of a technology that's close to 100 years old!
to me it looks like live camera, for the visual confirmation of critical components...
If you look closely, all the similar instruments are identical images, right down to the visible serial number. Which means the readings on them are not part of the simulation. That whole panel is no more than visual flavor for what the room looks like.
