Author Topic: 120VDC in to appliances and devices?  (Read 1869 times)
Offline lufihengrTopic starter
« on: September 07, 2023, 06:08:36 am »
Has anyone tested what happens if you put 120VDC in to a TV that has a switchmode PSU meant for 120-240VAC?
In theory it should work, no?
Asking because I would like to avoid using inverters, and modifying appliances like TV's with integrated power supplies is too time and cost intensive.
Thanks
Re: 120VDC in to appliances and devices?
« Reply #1 on: September 07, 2023, 08:14:56 am »
In theory yes, but bear in mind you're putting one half of the diode bridge on 100% duty cycle. Depending on the design specs, this might be problematical. In the unlikely event it's a half-wave rectified primary side, you'd have to get the polarity right.
The following users thanked this post: lufihengr
« Reply #2 on: September 07, 2023, 11:28:18 am »
Would it be better for the appliance to have 120VDC or 240VDC if the PSU is capable of taking 120-240VAC?
And would it technically be even better to have a 100% duty cycle polarity switching DC supply to it? Like have it switch polarity at 10, 50, 60Hz, essentially just a square wave going from +120VDC to -120VDC? Or is that worse than a pure sine wave? It would be easier to make than even a modified sine wave inverter.
Offline Gyro
« Reply #3 on: September 07, 2023, 11:58:51 am »
If it's a modern, reasonably large TV, you may need to consider how the PFC circuit would react to DC. I have a vague memory of this being discussed on the forum before, but not the outcome.
Best Regards, Chris
Online Ian.M
« Reply #4 on: September 07, 2023, 12:06:28 pm »
You are going to run into severe problems with switches and fuses, as they are extremely unlikely to be rated to break a >30V DC circuit.  Squarewave  AC isn't much better, as there is no 'dead' time round its zero crossings.  OTOH sinewave 120V AC has nearly a millisecond under 30V round its zero crossings, making low energy arcs much easier to quench.  Therefore, you'll probably need to replace fuses with DC rated ones and avoid powering with DC any devices with a mechanical or relay mains switch.
Then there's the issue of PFC circuits - some will be very unhappy with any input waveform that isn't somewhat sinusoidal.
On the subject of switching polarity, see https://www.quora.com/What-is-Quasi-Square-wave-or-Modified-Square-wave-Inverters
Even with dead time at zero crossings, and both peak and RMS voltages equal to sinewave mains, many appliances will run hotter or even fail if run from such a supply.
The following users thanked this post: Jeroen3, lufihengr
Online Psi
« Reply #5 on: September 07, 2023, 12:08:42 pm »
It's usually one of those, try it and see, things.
Sometimes it will work fine, sometimes it will not.
And occasionally you might burn something out, but it's rare.
The following users thanked this post: Someone, lufihengr
Offline Berni
  • Country: si
« Reply #6 on: September 07, 2023, 12:28:39 pm »
In most cases switchmode supplies run perfectly fine from high voltage DC. The diodes won't be run that close to the rating to be a problem.
But yeah in some cases PFCs might get unhappy when they expect to see a sine wave, but a lot of them still work.
And as said above the is a small but non zero chance that a PFC might get confused enough to blow up. Also the safety protections like fuses are not designed to break DC, so it is a bit of a safety issue doing this for daily use.
Offline Circlotron
« Reply #7 on: September 07, 2023, 12:47:21 pm »
On occasion I have used my Rigol DS2072 scope while sitting in the passenger seat of a moving car so I have had it running off an inverter that supplied a "modified sine wave", in other words +/- 340VDC at 50Hz, 2/3 on 1/3 off approx. The scope power supply has an X cap across the mains and it draws a bit of current during the fast transitions of the inverter power so I run it through an external bridge rectifier and feed that to the scope. Works great. Scope PSU does not have a PFC input.
Online NiHaoMike
    • Facebook Page
« Reply #8 on: September 07, 2023, 12:50:22 pm »
I suppose one could have a MOSFET/IGBT driven by a 555 to make pulsed DC at 170V or so which will be fine for AC switches.
Offline pqass
« Reply #9 on: September 07, 2023, 12:53:24 pm »
Some PC power supplies rely on a two capacitor voltage doubler after the diode bridge.
They won't work with 120VDC input.
But this may only apply to those supplies with a 120/240VAC selection switch.
http://www.righto.com/2021/05/teardown-of-pc-power-supply.html
Offline tom66
« Reply #10 on: September 07, 2023, 01:10:03 pm »
I've tried this to some extent with a few devices.
Rigol scope - works fine 50V upwards.  Draws 10W, so unlikely to wear the diodes even at the lowest input voltage.  Below 40V, once started, scope shuts down suddenly with no apparent side effects.  Current draw is minimal until startup works.
LCD TV - works ok up to 100V DC (had a PFC circuit) but below this power supply makes some very unhappy sounds and backlight/sound flutter badly.  Eventually LCD TCON lost its mind and started drawing all sorts of random patterns on the display in place of video, whilst sound continued OK.  Did not break anything.
various AC-DC PSUs - all seemed to work OK
Dell laptop PSU - did NOT work correctly, output pulsed on and off, laptop refused to charge.
The following users thanked this post: lufihengr, schmitt trigger
Offline amyk
« Reply #11 on: September 07, 2023, 01:40:05 pm »
120VAC is RMS so you should probably be aiming for ~170VDC instead (or 340 for 240VAC).
Offline Zero999
  • 0999
« Reply #12 on: September 07, 2023, 01:44:27 pm »
No, the switched mode power supply will be designed to work at a much lower steady DC volage, because the smoothing capacitor will discharge, during the zero crossings.
My Rigol DS1054Z oscilloscope works perfectly down to 36V. I even considered making a battery pack for it, but lost interest because I bought another oscilloscope with a rechargable battery.
https://www.eevblog.com/forum/testgear/battery-pack-for-rigol-ds1054z/msg717702/#msg717702
I'm not saying this will be the case for all switched mode power supplies, but I would expect it to work from a lower DC voltage, than the peak mains. As mentioned above, there are potential pitfalls, to running AC switched mode supplies off DC, but I've found most mains switched mode power supplies work perfectly well.
« Reply #13 on: September 07, 2023, 03:22:33 pm »
As a followup then, is there a point where it would just be easier/better to use DC power from batteries to spin a DC motor, that is connected to a generator? That would at least be a perfect sine wave :D
As you have probably gathered, the situation is a case where grid connection is not available, but the use of regular appliances is wanted.
Offline BeBuLamar
« Reply #14 on: September 07, 2023, 03:35:21 pm »
I work on a machine which has a PC used as the operator interface. They power the standard power supply with 220VDC and it works. I really don't know why they do it that way as they could feed the 220VAC directly to the power supply but they use a bridge rectifer and a large capacitor to create the 220VDC (actually it's more than 220VDC) to run the computer.
« Reply #15 on: September 07, 2023, 04:43:27 pm »
Depending on funds, a better solution might well be solar PV/a wind turbine and a decent inverter, or indeed a generator.
Offline Zero999
  • 0999
« Reply #16 on: September 07, 2023, 05:01:20 pm »
That's known as a motor-generator set and is the old fashioned way of doing it. Quite often the primary and secondary windings were on one armature, in which case it was known as a rotary converter. Imaging a DC motor, with three poles on the armature, each with a secondary winding, connected to a slip ring. The DC going to the commutator will be converted to three phase AC.
The disadvantages of motor generator sets are: low efficiency, more noise and higher maintenance, as bearings and brushes need to be replaced. The only advantages are they're more electrically robust and can withstand ionising radiation better than electronics.
Nowadays static, semiconductor inverters are used. A boost converter, takes the battery voltage up to the peak voltage of the AC output and an H-bridge converts it to AC. Cheap inverters produce a modified sine wave, whilst more expensive ones use PWM and a filter to give a pure sine wave. The only downsides are they're more vulnerable to over-voltage and ionising radiation, compared to motor generator sets.
If all you want to do is convert one DC voltage to another, use a DC to DC converter.
Offline Siwastaja
« Reply #17 on: September 07, 2023, 06:10:49 pm »
I have ran random switch-mode stuff out of DC and usually it just works. BUT:
That's quite an assumption. Cheap consumer electronics is often dimensioned close to destruction. Diodes specifically are annoying to design in because they dissipate surprisingly lot of power for quite small packages. Suddenly doubling (+100%, not something like +10%) the average power dissipation in a component is something I would not classify as "definitely no problem". I would keep an eye on it, or just bypass the bridge.
Offline Zero999
  • 0999
« Reply #18 on: September 07, 2023, 08:51:20 pm »
I think assuming the diodes are over specified is sensible with small power supplies, given 400V parts normally have current ratings of at least 1A.
Does it really increase the power dissipation in the diodes that much?
Don't forget that although the diodes only run at 50% duty when on AC, the peak currents are much higher, in a non power factor corrected design, whilst with DC it's more constant. I suspect the it's not that bigger difference.
Offline langwadt
« Reply #19 on: September 07, 2023, 09:43:12 pm »
but with ac the diodes are carry a higher peak current at the peaks of the period, with DC the diodes carry current all the time but it must be lower
Offline Zero999
  • 0999
« Reply #20 on: September 07, 2023, 09:59:00 pm »
I just said that.
Don't forget though that with DC, only two of the diodes in the bridge are conducting continuously, whist with AC, all four are used, with each pair conducting alternately.
I suspect the losses are over all lower with DC, probably not quite half though. If it's a bridge rectifier module, rather than discrete diodes, it's even better because the connections to the unused diodes will still provide a bit of heat sinking.
Offline amyk
« Reply #21 on: September 08, 2023, 01:36:50 am »
I've seen this in cheaper PC PSUs that are based on a voltage doubler, where in 120V mode two of the diodes in the bridge rectifier are not used, so to save the miniscule amount of extra cost of two higher-rated diodes, they use two bigger and two smaller diodes instead of a single bridge rectifier.
Offline Berni
  • Country: si
« Reply #22 on: September 08, 2023, 05:34:45 am »
The diodes are on the AC side where the continuous current is pretty low due to the high voltage. These diodes also have to survive the inrush current of the capacitors filling up if potentially plugged in at the peak of the sine wave. So they have to be a reasonably robust power diode rather than some tiny fragile signal diode.
Fair point on the capacitor doubler input stages. I live in the 230V land so i don't come across those (apart from perhaps the 110/220 switchable PSUs). Those would definitely not work with HV DC on the input. But id think those are pretty rare these days since most modern switching PSUs seam to be universal input 90 to 250V and those won't have one.
