Author Topic: 194 Transistor Digital Clock (no IC's)  (Read 5893 times)
Offline Ferroto
« on: May 19, 2010, 12:14:15 am »
Anyone ever take on a project this absurd just to say you can  :D
http://hackaday.com/2010/01/11/194-transistor-clock-will-blow-your-mind/
Online EEVblog
Re: 194 Transistor Digital Clock (no IC's)
« Reply #1 on: May 19, 2010, 02:58:36 am »
Beautiful, just beautiful...
Dave.
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #2 on: May 19, 2010, 03:07:58 am »
Wow, that's a lot of work! I have wanted to build a Nixie clock for some time and I think using transistors rather than ICs would suit the ethos pretty well. I can understand why they packaged it all on one board (if ya got it, flaunt it!) but I think for practical purposes it would be better with a horizontal motherboard and slot-in daughterboards and display board. Superb though.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: May 19, 2010, 09:35:08 am »
.. orf couse if you want to go really hardcore, how about an all-tube nixie clock
Day Job: Mostly LEDs
Offline thedigitalprincess
  • DERP
« Reply #4 on: May 19, 2010, 10:04:21 am »
Haha, my friend showed me that a while back. It's wonderful xD
Got done doing 126kmph on the Fed Hwy at Collector but not at Base or Emitter.
Offline Ferroto
« Reply #5 on: May 19, 2010, 11:36:36 am »
Dave.
Ya seeing someone do a project like that makes me appreciate how far we've come.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #6 on: May 19, 2010, 12:00:43 pm »
I used to build things like that, all discrete parts, because that's all we had.  When I began, the 555 timer was just designed, and the most often used IC was the 741 op amp.  Now, you can build it, just for looks and nostalgia.
Interestingly, some appliances do come with transparent cases, so you can appreciate the guts, the Pickit 3 comes to mind.
Best Wishes,
 Saturation
Online EEVblog
« Reply #7 on: May 20, 2010, 02:42:15 am »
I wonder if he simulated that first?
So easy to goof something at the schematic or layout stage.
Dave.
Offline saturation
    • NIST
« Reply #8 on: May 20, 2010, 11:33:40 am »
Yep, older chips mostly were semiconductors and resistors, like the 555 timer.  Now, many components exist inside the chip.
I'd think you'd want to simulate this, there's too much that can go wrong or interact.  In the clocks I've designed, all you need is tap half wave rectified step down AC mains to get a 60 Hz pulse [ in the USA] to serve as a clock signal, then the rest of the circuitry is a counter adjusted to read out in time, and the power supply.
From the layout of the board, the repeating nature of the sections looks like the designer fleshed out some chips into discrete components.
ic is just a compact version of transistors right? correct me if i'm wrong.
the picture above shows a magnificent arragement of components IMO.
Dave.
Best Wishes,
 Saturation
