Make sure your variac is wired correctly, N to N, G to G with a good low impedance between them (sub ohm). If it was wired incorrectly (a 5 terminal variac, for example, could be mistakenly wired wrong) it could appear to work normally, but if you measured neutral to ground with it on, you may see some voltage, which would trigger the site wiring fault light.
