Sniff Sniff ??.... Aahh.... I can still smell the
Trichlorethelene dipped little leather pads on sticks,
while I cleaned
thousands of such
rotary/relay contacts about 45 years ago !!!!
[Edit] Just saw TerraHertz comment after posting!
Which also just reminded me when about (35-40 ?) years ago, I was involved with a HUGE construction for
an automation plant, involving about
9000 relays/timers, and
500 miles of internal building wire, over about
18 large conjoined panels. About 2 years before the advent of
PLC's !! which would make it superfluous !!
ALL the many thousands of panel interconnections had both ends of all the wiring
numbered/lettered with
slide-on coding, so that after testing in Adelaide, ALL the
massive looms were disconnected & boxed, to be
sent to Western Australia with the Panels, for re-connecting again. And it all worked !
The circuitry was so complex, that each
Sprecher & Schuh relay, was customized with various 'contacts', like a Lego Kit,
not only for the obvious N/O & N/C contacts, but some were often delayed, so as to
make/break before others....
Sorry about rambling on !! but I don't have much left now, than to 'remember'
