Author Topic: 2-pads printer ink chip?  (Read 560 times)
Offline bitwelderTopic starter
« on: November 01, 2020, 05:38:11 pm »
I was recently replacing the toner cartridge of my Oki laser printer.
Looking at the 'smart' ink chip on it, it's a 6-pins SMD chip (SOIC-6 perhaps?) with only 2 pins connected
to external pads on the tiny PCB.
With only 2 terminals, how does in general such a chip work?
Is the exchanged data encoded in the supply voltage, or does it communicate
in some other way, e.g. a Hall (or other magnetic field) sensor?
Offline ebastler
Re: 2-pads printer ink chip?
« Reply #1 on: November 01, 2020, 07:13:28 pm »
One solution is commercially available as "1-Wire", by Dallas Semiconductor.
https://en.wikipedia.org/wiki/1-Wire
It charges a capacitor to buffer the supply voltage while serial data communications are underway.
Offline daqq
  • Country: sk
    • My site
« Reply #2 on: November 01, 2020, 07:32:03 pm »
There are a few standards that allow communication and power over a single wire + GND. 1 Wire or the Microchip standard:
http://ww1.microchip.com/downloads/en/DeviceDoc/AT21CS01-AT21CS11-Data-Sheet-DS20005857D.pdf
There are actually crypto authentication devices that enable single wire communication, can't remember which devices, designed precisely for this situation.
« Last Edit: November 01, 2020, 07:33:41 pm by daqq »
