Author Topic: 2001 film ><Tektronix probe  (Read 1565 times)
Offline jonpaulTopic starter
    • IEEE Spectrum
« on: December 20, 2022, 03:25:01 pm »
A walk down memory lane....
In 1968....Stanley Kubrick's "2001: A Space Oddssey" used a  TEK P6006 x10 probe for checking the AE-35 unit per computer HAL-9000 fault detection.
When the testing did not confirm HAL-9000 prediction of failure, Frank Poole went EVA to exchange AE-35 (comms dish feed LNA) and the rest is for you to recall.
So the scene is central to the story line by Arthur C Clarke and Stanley Kubrick.
Now, In my boxes of 100s of old probes,  I just discovered two, P6006 (10X, 25 MHz!) with tips and clips!
Your memories of old probes and 2001 A Space Odyssey are appreciated! Enjoy!
Jon
An Internet Dinosaur...
The following users thanked this post: pardo-bsso, MrMobodies
Offline Infraviolet
Re: 2001 film ><Tektronix probe
« Reply #1 on: December 22, 2022, 05:01:41 am »
A good film, but you don't get the proper experience unless you watch 2010 The Year We Make Contact straight afterwards.
Online coppercone2
« Reply #2 on: December 22, 2022, 05:59:00 pm »
Yes thats the screw probe I have. When I got it in a ebay grab bag I thought it might be a special probe for threading into threaded connections. And it can be, if you make brass adapters for it. An end to screw terminal block bull shit?
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #3 on: December 22, 2022, 06:04:30 pm »
Jon
"Well HAL ... I'll be damned if I can find anything wrong with it."
The following users thanked this post: jonpaul
    • IEEE Spectrum
« Reply #4 on: December 22, 2022, 06:30:04 pm »
These 1960s probe P6006-9 are useful on big équipements with moving parts, high voltage, etc where our modern tiny probes are easily damaged
The large screw on tips are fine for industrial applications and the 600 V ration better than the 400 modern probes.
Jon
Offline tggzzz
« Reply #5 on: December 22, 2022, 09:44:15 pm »
Pah! You think that's a robust Tektronix HV probe?!
Here's a picture of a real Tek HV probe, alongside a 500V probe for comparison. (Apologies to the screenwriters of Crocodile Dundee)
Or, of course, a real real Tek HV probe...
« Last Edit: December 22, 2022, 09:47:40 pm by tggzzz »
Online Benta
« Reply #6 on: December 22, 2022, 09:54:50 pm »
“I'm sorry Dave, I'm afraid I can't do that."
The following users thanked this post: Ed.Kloonk
Online xrunner
« Reply #7 on: December 23, 2022, 02:36:06 am »
I've watched that movie many many times - I love it. When they were probing the AE35 unit they didn't show what the probe was connected to. But I would assume it wasn't a stand-alone scope but an input to HAL (may have been a "scope" presentation to the men on one of the screens). He just analyzed the DC level or waveform the human put the probe on and then directed him via the PCB picture where to go next with the probe.
Offline EPAIII
« Reply #8 on: December 23, 2022, 07:45:42 am »
Yes, I remember those. I may even have one or two laying around. Or some pieces thereof.
And the Death Star used a GVG-300 (analog) video switcher to control it's planet busting weapon. I spent a whole week doing all the set-ups on one of those.
Hollywood has no shame.
« Last Edit: December 23, 2022, 07:50:12 am by EPAIII »
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
    • IEEE Spectrum
« Reply #9 on: December 23, 2022, 01:13:22 pm »
Ré HV probes, there's a x100 tektronix but yes P6013/6015 are tge industry standard for HV work.
The P6015 uses a banned Freon as insulation, with no gas, the 40kV rating reduces to 15..20 kV.
The current version ( $$$) 40 kV Tektronix is P6015A, no freon , much smaller compensation box,
The main drawback of these enormous probes is indeed their size.  We use tie wraps or tape to fix the probes on the DUT.
Instead, for my  work 400..600 V like tube amps, mains, SMPS offline these old P6006..6009 are ideal.
Happy probing!
Jon
Offline tggzzz
« Reply #10 on: December 23, 2022, 01:46:14 pm »
Any 40kV probe needs to be large. Even those that connect to voltmeters!
For example, I have a Brandenburg 109m, and the probe is about the same length as the P6015. The Testec TT-HVP40 is longer.
Offline rdl
« Reply #11 on: December 23, 2022, 02:00:47 pm »
I remember going to see 2001 as a school field trip when it first came out. I didn't see it again for probably 20 years or more. I remembered it as being really long and having a weird ending, but I liked the space ships and the moon base parts.
    • IEEE Spectrum
« Reply #12 on: December 23, 2022, 02:13:00 pm »
Had worked on HV laser, arc lamp, avaionics, up to 70 kV.
Have several of the  TEK  P6015 Freon, 40 kV old TEK
a really excellent P6015A silicon insul 40 kV
Not a scope probe but HV ....Danbridge Danish 30 kV insulation tester with RG6/U cable and huge probe
Bon Fetes!
Jon
Offline David Hess
  • DavidH
« Reply #13 on: December 23, 2022, 02:25:20 pm »
The Tektronix P6009 is a x100 probe with 10 megohm input resistance, so it includes an internal shunt resistance and can be used to safely make AC coupled measurements without applying high voltage to the oscilloscope's AC coupling capacitor.
