Author Topic: 2008 Fluke 87V  (Read 4688 times)
Offline SafeadvisorTopic starter
2008 Fluke 87V
« on: October 13, 2012, 12:58:22 pm »
I just purchased a new in the box Fluke 87V on eBay.  I did not realize it was built in 2008.  Is there any advantage to one built in 2012?  If so are they upgradable?  Thank you for your help.
Offline ProBang
Re: 2008 Fluke 87V
« Reply #1 on: October 14, 2012, 03:51:15 am »
Hello.
Just two thoughts...
1. The calibration is out of date. Probably the 87V is quite in spec...
- but you can't be sure without a new one.
2. The 87V from 2008 is sensible for GSM-Frequencies.
Look at Dave's Video-Blog #112:
Fluke fixed it in the middle of 2011. With a modified PCB.
Because that's a hardware- issue, there's no updating possible.
Look at Dave's Video-Blog #185:
Greetings,
Hartmut
If you think my english is bad...
- then should you read my french!
Offline little_ear
Re: 2008 Fluke 87V
« Reply #2 on: October 28, 2012, 10:35:02 am »
Hello!
I am new on this forum and i hope my comment and question is valid here.
I got a 87 V which seems to be a from (2008 or) 2009 (Manual Rev. 08; the back of my Multimeter says "09").
The Rev. Board Version says: 10
I got no issues with my cellphone at all.
In Addition I was wondering if that GSM issue could be caused by the firmware itself (and not by the shielding or board schematics). So i tried some stuff to find out if there is any way to see the firmware version.
I found the following stuff - does anyone know what this means?:
- Turn off the 87V
- Press and hold: AutoHOLD
- Switch to DC Volage
Now my Multimeter says: 3.01
Could this be the firmware?
Kind regards
« Last Edit: October 28, 2012, 12:00:47 pm by little_ear »
Offline firewalker
  • Country: gr
Re: 2008 Fluke 87V
« Reply #3 on: October 28, 2012, 12:40:50 pm »
The owners of old Fluke 87V can ask for a replacement/repair for the GSM issue?
Alexander.
Offline little_ear
Re: 2008 Fluke 87V
« Reply #4 on: October 28, 2012, 01:20:50 pm »
This is what I found regarding: Fluke fix GSM bug:
http://www.flukecommunity.com/forums/showthread.php?s=93e2a25ba9bd419b6051adc9fae4ebe9&t=3348&page=4&pp=10
Anyone did tried the following stuff?
- Turn off the 87V
Which Numbers does your Multimeter display?
Offline little_ear
Re: 2008 Fluke 87V
« Reply #5 on: October 28, 2012, 08:23:14 pm »
Tested with 3G and 2G.
Using even 2 Smartphones next to the Multimeter. (also at the same time)
« Last Edit: October 28, 2012, 08:33:08 pm by little_ear »
Offline SLJ
    • Steve's Antique Technology
Re: 2008 Fluke 87V
« Reply #6 on: December 13, 2012, 12:21:29 am »
Fluke responded to my GSM rev 11 question:
Fluke:      -  You'll need an 87V with a > S/N 19470148.
Update:  New 87V arrived today.  Ser. # 21950XXX.   I checked and it's Rev 11.   Pressing AutoHOLD at turn on shows 3.03
UPDATE NOTE:  I contacted Fluke for the serial numbers of the updated versions before I purchased mine.  They did not replace my unit.
« Last Edit: November 13, 2013, 11:52:07 pm by SLJ »
