Be interesting to see the inside of a Chinese tig unit. Cant think why any one who uses a tig welder seriously would by Chinese, I bought a Danish made Migatronic tig welder in 1993 it is as good today as when new the same goes for the Migatronic mig welder, The best welding plant tends to be Scandinavian in origin although there are some good US made machines, like Miller I once had a Lincoln plasma cutter that was more trouble than it was worth, I found that the best ones came from Russia if you wanted high power, 100 amps and above.
