Author Topic: British lighting companies don't seem to employ Electronics Engineers...why not?  (Read 973 times)
Offline ocsetTopic starter
Hi
In UK today, there  are huge numbers of lighting companies, all of which call themselves “lighting designers and manufacturers”
For example, there’s………………………
Acdclighting.co.uk
https://londonlighting.co.uk/
https://www.endon.co.uk/
https://www.keslighting.co.uk/
https://www.darlighting.co.uk/
https://www.whitecroftlighting.com/
…and literally 100’s and 100’s more.
None of them seem to employ any electronics engineers.
When you look on linkedin, none of these companies seem to have any electronics engineers.
So who designs the ballasts and the  LED drivers  for them?
Is all their stock from China? (ie all the ballasts and LED drivers and Switch mode power supplies)
Offline nctnico
A lighting designer isn't about designing electronics but choosing the right lamps and fixtures for a particular purpose. They don't need EEs for that. EEs would probably suck at that job.
The following users thanked this post: ocset
Offline Gyro
Looking at the links. All of those companies are retailers / distributors. If you look at their ranges, they buy from many different manufacturers.
Best Regards, Chris
Offline Benta
Lighting design is about optics. Whether they use a halogen bulb or an LED solution is moot, the light sources come from outside.
