Author Topic: When was the first electronic bitmap sign invented?  (Read 4447 times)
Offline W-B_LiteBrite
Re: When was the first electronic bitmap sign invented?
« Reply #25 on: October 07, 2023, 12:03:40 am »
The Motograph News Bulletin, or “zipper” as it was known informally, was an impressive sight when it was first unveiled in the fall of 1928. It extended 380 feet around the fourth floor of what was then the Times Tower at One Times Square—the second tallest building in Manhattan when it opened in 1904. With a band five-feet tall, the moving letters, comprising 14,800 light bulbs, were visible from a distance of several city blocks.
With all due respect, and from looking at key pictures and old films of the "motograph" in action, no way was it 14,800 bulbs.
First of all, there are the dimensions of the building itself:
43rd Street - 20' (240")
Broadway - 143' (1,716")
42nd Street - 58' 4-1/8" (700.125")
Seventh Avenue - 137' 11-3/4" (1,655.75")
Also, several photos were taken of the 43rd Street side during World War II when it was not running. The "Motograph" (as it was originally known) was built 12 rows high on a 60" high ribbon (thus each row was separated by 4.5"). On 43rd Street, 720 bulbs were on that side. Or an average of 60 per row. Meaning that the vertical columns were spaced 4" apart. 18 bulbs were missing from the bottom left side, and 6 from the top right - all to conform that side to the angles at which they were built and positioned (about 9.4 degrees, from what I could tell in terms of the slant).
Thus, by such measurements, it is estimated that the Broadway side had a total of 5,148 bulbs (429 average per row), the 42nd Street side 2,103 ( > 175 average per row) and the Seventh Avenue side 4,965 ( < 414 average per row). The grand total of bulbs, give or take:
12,936
The other factor, in studying old photos and films, is how many characters were on each side at one time. Close-up, character spacing was about 12.5 bulbs, give or take. (The way the characters moved seemed reminiscent of the old interlacing on analogue TV's.) Thus by that factor, there was an average of:
- 4.8 characters on 43rd Street
- 34.32 characters on Broadway
- 14 characters on 42nd Street
- 33.12 characters on Seventh Avenue
As the headlines passed, on each corner one letter disappeared for a bit. This was where the ornaments connecting each side were mounted.
If the four sides were attached end to end, they would consitute 1,078 average rows for a total of 359' 4".  On each corner as the message advanced, about one character was missing; if accounted for, that would add 16 feet (4 feet per side) to the figure, thus the total would be about 375' 4".  (That's on the level where the top row was; going to the furthest up it'd be about 5' max per side, thus close to the 380' figure cited.)
On the 1997 updated (Mark III) zipper around the building, there may have been 227,200 LED's, but I counted 22,720 pixels total.  Meaning, 10 LED's per pixel.  That used Daktronics Sans Serif 16.
But the Mark II zipper, my personal favorite, used from 1965 to 1997, used the same dimensions for bulb spacing (4" between columns, 4.5" between rows), 11 rows high on a continuous band measuring 57" tall.  Its initial controls - operated by Life magazine from 1965 to 1971 - were from Chicago-based Naxon Telesign with which sign-maker Douglas Leigh had a long relationship (developed in part because of Artkraft Strauss' exclusive arrangement with Trans-Lux whose zipper controls were used for many a "Flashcast" or "Adcast" traveling message sign on Artkraft billboards up and down the Square).  For this the company devised a round display font for use on zippers like the one being built not only there, but also atop the Walgreens building on the corner of State and Randolph Streets in Chicago.  (Before then, they used a square / boxy font that had been in use on all their machines built since 1939.)  The Times Square "Mark II" zipper consisted of 12,408 bulbs - or 1,128 per row.  Three sides had the Life logo flashing in-between headlines (after Life dropped out and Reuters began operating it later in '71 for a 6-year period, the red bulbs were taken out and replaced with other A19 inside-frosted bulbs, making them look like Velcro add-ons).  The bulbs used to flash the headlines at the start were (apparently) 30 watt (definitely) A21 reflector bulbs.  From about 1972 to '77 they used a Digital Equipment Corporation-derived dot matrix font that was used on Reuters' Extel 70 teleprinters (see below - would anyone know the exact name of this predecessor to the RO3-2513 font used on Apple II computer monitors?).  Then starting in 1986 when New York Newsday took over operation, they began using an early Daktronics Venus system with Sans Serif 7 for the headlines . . . and Fixed Width 7 for the time and temperature checks.
Offline jonpaul
« Reply #26 on: October 07, 2023, 05:20:41 am »
1928:
Times Square Manhattan NYC
NY Times news
Incandescent lamps and relays.
https://www.timessquarenyc.org/history-of-times-square
Jon
Jean-Paul  the Internet Dinosaur
Offline tooki
« Reply #27 on: October 07, 2023, 07:10:36 am »
1928:
NY Times news
Jon
The link in reply #11 above contains a much larger version of that photo, rather than the uselessly small thumbnail you attached.
« Reply #28 on: October 07, 2023, 11:55:50 am »
I also wish to note that on the Smithsonian Institution website relating to Douglas Leigh's papers and photos, a picture of the Times Square zipper's 1965-71 Chicago sister (see below) had the caption misidentify the period taken as 1940-45, though clearly the Life logo as it looked from 1961 to its demise as a weekly in 1972 was clearly in evidence (as was the round Telesign display type).  Maybe they confused the pic with that of the World War II-era zipper across the street (at Seventh and 42nd, atop the Rialto Theatre) that flashed news headlines in the daytime per dimout requirements - but was mounted by Artkraft Strauss and its zipper controls from Trans-Lux, and operated by Coca-Cola and the radio station then known as WJZ, now WABC.  (Some pics taken from the SE corner of 42nd and Broadway facing northwest on D-Day showed this "other" zipper in operation, across from The Times' as their headlines were flashing.)
« Last Edit: October 07, 2023, 11:59:11 am by W-B_LiteBrite »
Offline AlbertL
« Reply #29 on: October 09, 2023, 03:59:29 pm »
This film shows the paper-tape equipment for the Motograph on the giant Chevrolet sign in Chicago:
Offline ebastler
« Reply #30 on: October 09, 2023, 04:34:15 pm »
Looks almost like the great clip posted by a guy named AlbertL in reply #18, 3.5 years ago!  ;)
