General => General Technical Chat => Topic started by: madires on October 27, 2019, 10:30:40 am
Title: 400 watts across 325 meters by laser
Post by: madires on October 27, 2019, 10:30:40 am
400 watts across 325 meters by laser:
https://www.nrl.navy.mil/news/releases/researchers-transmit-energy-laser-power-beaming-demonstration (https://www.nrl.navy.mil/news/releases/researchers-transmit-energy-laser-power-beaming-demonstration)
Title: Re: 400 watts across 325 meters by laser
Post by: Simon on October 27, 2019, 10:55:17 am
what was the efficioncy. With 400W they could not have been making coffees at great speed.
Post by: mikeselectricstuff on October 27, 2019, 12:03:37 pm
2kW in I think I saw somewhere.
Would love to ask the CEO to stick his hand in the beam to demonstrate the safety they claim.
Post by: Simon on October 27, 2019, 12:07:02 pm
pft? they claim that 400W concentrated beam is safe? my expresso maker uses 1.1 kW during heat so at the least they have to store the power and hope for less than 30% duty if you assume decent receiver conversion and running laptops.
Post by: StillTrying on October 27, 2019, 12:29:47 pm
The vid says 400W DC into the DC-AC inverter, so probably ~2kW in the actual beam. :o
In the US you've only got to mention the military and forward operations base to keep the funding flowing, in the EU we have to mention green energy, graphene, nano-particles and sustainable, the idea itself doesn't have to be useful, practical or even work. :horse:
Post by: Simon on October 27, 2019, 12:59:06 pm
Oh great 20% efficiency, may as well use wires. They make claims about the wireless transfer to drones but the tracking and delivery to a moving thing that needs to keep pointing at the beam is 99% of the job so they have achieved absolutely nothing.
True, I should have sought funding for my solar panels......
Post by: coppice on October 27, 2019, 01:07:08 pm
The military has a huge number of applications where wires don't cut it. 20% efficiency is satisfactory for most of them, as they bring huge savings in other ways, like allowing things to stay on station indefinitely.
The tracking issues have already been well researched by the US military, in their work on shooting down flying objects using lasers. They are actually pretty good at sending out a laser beam, and keeping it accurately aligned on a moving target. Its the receiving and using of the power by the target, rather than letting it burn a hole, which seems to be the focus of this new demonstration. If they can keep power flowing smoothly to one of their drones it could stay airborne indefinitely, and transform the business of surveillance.
Post by: iMo on October 27, 2019, 04:53:58 pm
..unless it is raining, snowing, foggy, dusty, or low clouds :)..
Post by: Brumby on October 27, 2019, 10:47:12 pm
Safety is actually covered in the article.  Nobody said nor inferred that the laser beam is safe in itself - but the overall system is safe.  That raises questions about failure modes of the safety system and that would be the direction where my reservations lie.
Post by: SiliconWizard on October 28, 2019, 12:23:19 am
"the safety system is designed to detect objects before they ever reach the laser beam, and turn it off."
I wonder what could ever go wrong with that.  ::)
Post by: I wanted a rude username on October 28, 2019, 02:48:33 am
The mirror looks quite large. Hard to tell by eye, but I estimate a 150 mm wide beam. That's about 175 cm2, or (assuming a 2 kW beam) roughly 10 W/cm2, which you could safely pass your hand through ... quickly. Somewhat less concentrated than the heat from a candle, anyway.
What it certainly isn't is eye-safe.
Post by: ejeffrey on October 28, 2019, 03:17:06 am
I think AoE mentions an application of a light and solar cells to create an isolated power supply at the business end of a particle accelerator with several million volt acceleration potential.  Of course on a smaller, less mobile scale than this, but the point is there are applications where you need to get the power there and the efficiency is secondary.  If your alternative is not wires but batteries or generators you might be willing to put up with a lot.
Post by: coppice on October 28, 2019, 03:35:32 am
For decades people have been powering monitoring electronics sitting at extremely high voltages, by sending light through the air or an optical fibre to a photovoltaic cell at the monitoring electronics.
Post by: BravoV on October 28, 2019, 04:35:58 am
Wonder if they provide a loaner unit for Nigel Stanford.  >:D
https://www.youtube.com/watch?v=bAdqazixuRY (https://www.youtube.com/watch?v=bAdqazixuRY)
Post by: vk6zgo on October 28, 2019, 07:52:53 am
Maybe EIRP, which is meaningless in the power transfer context.
The actual, useable power must always be less than the DC input.
