I'm shitting on a product that - at best - is a tiny bit better (light quality-wise) than its competitors. Also, color me entirely unsurprised when I noticed that YujiLED has no distributors. Period. Doesn't really sound like a massively big player in the area, and it explains why I haven't heard of them.
And the fact that you are shitting on it for being "a tiny bit better" is proof that what I said is correct - you don't understand the product and don't know anything about it by your own admission. So why shit on it because of the name and country of origin and just assume it's crap? You were mistaken in your assumptions about this company - Yuji is not one of those Shenzhen factories cranking out junk LED's using fake Cree dice... they were more of a phosphor specialist whose niche is in the absolute highest quality light output possible who got into LED's to offer end-to-end solutions. They are a big player in THEIR niche. It is a small niche but it does have substantial crossover into the high end of the commercial lighting market (museums, art galleries, high-end residential lighting, some commercial lighting such as high end car dealerships, some restaurants, etc).
Incidentally, their graphs show why the efficacy is terrible: They're using UV emitters - probably 405nm chips - instead of blue emitters.
Their highest CRI LED's (98CRI) use violet dice which drops the blue spike you get when using a blue die. Efficacy suffers, but again, this is the niche - the absolute highest quality light. As you know, CRI - even expanded CRI that lists R values across the board - does not tell the whole story. They also have blue die LED's that have guaranteed 95CRI with excellent color quality across the spectrum. These have better efficacy at a cost of light quality.
Really? Comparing a LED for high-end architectural lighting and the movie industry to... LEDs for high-end architectural lighting and the movie industry is apples and oranges? The Bridgelux Decor series would like a word, for instance. Incidentally Bridgelux also offers a 5600k LED with a CRI of 97 (the BXRC-56H10K0-D-74). It does 128 lm/w. And the datasheet for the 500W YujiLED does list it as having a R9 value of just 80; while that may be a mistake, it's their mistake.
Yes, apples and oranges.
This particular LED you are crapping on is not comparable to the Citizen or other LED you listed as being better. The whole point of this one is light density per surface area in conjunction with light quality. This is achieved with the dice, phosphor and thermal resistance of the packaging. For lighting a factory floor, that's irrelevant. For many commercial lighting applications, it's irrelevant. For some applications, it's critical - and those are the kind of applications where the designer is even thinking about a $500 LED. You compared it to the Citizen CLU which is just silly... again, that's like looking at a Lamborghini and saying "pffft, my uncle has a turbocharged Toyota that will blow this thing away". Apples and oranges. I am not sure where you are seeing the datasheet - their website shows only the datasheet for the 100W version and it doesn't list R9 values, but the site itself shows R9 values in the mid-high 90's for this LED.
As for the Bridgelux Vero's... I know them well and I have used thousands of them over the past few years. I have also used many thousands of the Yuji LED's (not the ones the OP mentioned, but I have used thousands of Yuji COB and smaller 5730 and 3030 SMD LED's, both violet die and blue die). I like the Bridgelux parts very much, but throwing out that specific part number Bridgelux doesn't change anything. First, have you ever tried to buy one of those? You can't. Nobody has them in stock. In fact, nobody has any Bridgelux 97CRI LED's in stock above 3000k in any package. I am not convinced that 5600k/97CRI LED even exists other than in a datasheet. Digikey says you can get them with a 50MOQ, but I've tried and the order gets cancelled unless I am willing to commit to a MUCH bigger order. Bridgelux does have 90CRI (typical) LED's out in the wild, but if you look at their datasheets, those 90CRI LED's only have R9 values of 50.
The standards for film/video/photo lighting are 3200k/5600k (less important than some years ago but those two specific numbers persist)... and Bridgelux doesn't have a 3200k super high CRI LED. The 5600k one is unobtanium.
Yuji on the other hand, you can go to their website right now and buy their 98CRI (Re) LED's, and you can get that LED with those specs in any color temperature you want... 2700k, 3200k, 4000k, 5000k, 5600k, and 6500k. Or you can go with their 95CRI min (Re) /97CRI typical LED's that use blue dice and are the equivalent to the Bridgelux LED's - and again you can buy them in any of the available color temperatures up to 6500k with those specs without special orders or waiting.
Lastly, as you probably know, even expanded CRI is largely outdated these days. For film/video, TLCI is taking over, and both Bridgelux and Yuji publish this data. Bridgelux' 5600k/97CRI Vero LED's have a TLCI rating of 97, Yuji is at 99.
Yuji is not some fly-by-night Chinese company making dubious quality LED's. They have an excellent reputation and are most definitely a leader in their niche of the industry. You haven't heard of them, fine... but you shouldn't shit on them just because you haven't heard of them and because they are Chinese. Their product is top-notch.
