Author Topic: Removal of conductive paint from glass  (Read 5878 times)
Offline dexters_labTopic starter
« on: September 22, 2016, 08:47:26 am »
i have a photomultiplier here i'm trying to remove some brown/red conductive paint from and it's proving difficult, what i thought would be a 5 min job isn't.
the pmt is junk, i just want to remove the red paint from the back and the neck to make it more ornamental
so far the most productive method has been to just use a sharp blade to scrape it off but i have also tried:
white spirit, ethanol, petrol, cellulose thinners, IPA, nitromores paint stripper and various other solvents i found but nothing touches it
i do have dichloromethane, but that would probably decompose the plastic plug end and probably detach the blue filter that's bonded to the front. I would also rather not waste that much of my dichloromethane!
any suggestions?
Offline daqq
  • Country: sk
    • My site
Re: Removal of conductive paint from glass
« Reply #1 on: September 22, 2016, 09:43:59 am »
Acethone applied targetedly by a small swab?
Offline AntiProtonBoy
  • I think I passed the Voight-Kampff test.
« Reply #2 on: September 22, 2016, 09:49:26 am »
Few other things to try:
* Give it the ultrasonic cleaner treatment. It might take a while before the paint will start flaking off.
* Perhaps give it an acetone bath for a good couple of days. Warning, do not allow acetone to make contact with plastic parts! Only immerse the glass bits.
* Bath of potassium hydroxide or sodium hydroxide (aka caustic soda). The former is harder to get but it is much more potent. Warning, highly corrosive, it will destroy aluminium. Turns your nails into soap. Handle with tick rubber gloves and good eye protection.
Offline Psi
« Reply #3 on: September 22, 2016, 10:05:10 am »
maybe you need one of these   :-DD :-DD
Offline daqq
  • Country: sk
    • My site
« Reply #4 on: September 22, 2016, 04:06:14 pm »
Bad bad idea... if nothing else it's a glass tube with delicate bits inside. You'd probably end up with a broken bulb and lots of photomultiplier bits in the cleaner.
« Reply #5 on: September 22, 2016, 04:19:51 pm »
Yeah you're probably right, although I would've thought that ultrasonic cleaners work at water/solid interface where cavitations are produced to dislodge material on the surface. Takes a lot of energy to break glass, whose resonant frequency must be close to one of the harmonics of the ultrasound.
This thing is hypnotic. I want one... for, um, reasons.
Offline rdl
« Reply #6 on: September 22, 2016, 04:27:52 pm »
Most paint would have be affected, at least a little, by one or more of those.
I wonder if it's actually paint? Maybe it's some kind of glaze or ceramic that's actually heat fused into/onto the glass surface.
Offline firewalker
  • Country: gr
« Reply #7 on: September 22, 2016, 04:35:46 pm »
Hydrofluoric acid and/or Piranha solution?
Alexander.
Offline PartialDischarge
« Reply #8 on: September 22, 2016, 04:40:39 pm »
Alexander.
HF will eat the glass, he needs nitric acid in around 30%-60% concentration.
« Last Edit: September 22, 2016, 04:43:34 pm by MasterTech »
Offline Cyberdragon
« Reply #9 on: September 22, 2016, 06:13:18 pm »
There are several of these machines available, just look for laser paint stripper.
http://www.cleanlaser.de/wEnglish/produkte/high-power-cl-1000.php
Just don't burn the house down.  ;)
*BZZZZZZAAAAAP*
Voltamort strikes again!
« Reply #10 on: September 22, 2016, 06:45:22 pm »
quite a few suggestions there, thanks!
i think i will try some acetone first off, cheap and easily available
Offline _Andrew_
« Reply #11 on: September 22, 2016, 06:56:10 pm »
Have found in the past when using cellulose thinners to clean of old anti corona lacquer from crt's the thinners were more than happy to start removing the conductive paint as well.
Offline Alex Eisenhut
  • Place text here.
« Reply #12 on: September 23, 2016, 01:22:05 am »
Online tggzzz
« Reply #13 on: September 23, 2016, 06:57:58 am »
I dismembered a broken CRT, and found part of it was opaque ceramic, not glass.
FFI, including pictures, see https://entertaininghacks.wordpress.com/2016/03/09/rescuing-a-broken-tektronix-465-crt/
« Last Edit: September 23, 2016, 07:00:41 am by tggzzz »
« Reply #14 on: September 23, 2016, 11:03:41 am »
yea, the knife blade works ok, it's very very hard though and the rounded edges of the glass make it hard work to get off.
it's paint for sure, you can see where i have removed some of it in my picture
