Author Topic: 7.83HZ Schumann Ultra-low Frequency Pulse Generator  (Read 1538 times)
Offline ETITsynthesizerTopic starter
« on: May 14, 2020, 03:00:52 am »
I'm genuinely curious. can this device generate some static electricity or some magnetic field at such low frequency that would actually make my tea ceremony better. that is what the description says. if it works, how does it work. how do you calibrate the frequency to match the natural Schumann waves of the earth? how do you measure ultra low frequency RF? how does the device interact with me?
https://www.ebay.com/itm/7-83HZ-Schumann-Ultra-low-Frequency-Pulse-Generator-with-USB-Cable-FM783/383251125458
Offline OwO
  • Country: cn
  • RF Engineer.
Re: 7.83HZ Schumann Ultra-low Frequency Pulse Generator
« Reply #1 on: May 14, 2020, 05:25:24 am »
It's a quack device. That antenna is nowhere big enough to radiate any meaningful far fields at 8Hz, and even if you do build a huge antenna your signal is going to be drowned out by all the lightning strikes.
Email: OwOwOwOwO123@outlook.com
« Reply #2 on: May 14, 2020, 01:44:32 pm »
can I just wear it on my head for a limited time?
Online tom66
« Reply #3 on: May 14, 2020, 01:50:49 pm »
You can wear it on your head.  It won't do you any harm, but it also won't do anything.  So not sure what you intend to achieve, other than looking a bit peculiar.
Offline SiliconWizard
« Reply #4 on: May 14, 2020, 01:51:35 pm »
A tinfoil hat would probably be more effective. ;D
