Author Topic: Q: TEXT MODE SMS - 2G vs 3G formatting differences?  (Read 719 times)
Offline SL4P
  • There's more value if you figure it out yourself!
« on: May 15, 2016, 09:37:41 am »
I've been doing some work on parsing multi-line text messages (Text mode SMS).
I was originally SENDING with a couple of different SIM900 & Telit 2G modems (Internode SIM / Optus),
which format the messages as....  LF between lines
<header line> CR LF <text line 1> LF <text line 2> LF <text line n> CR LF LF
When I i switched to a SIM5320 3G modem with a Telstra 3G SIM, the CR LF pairs changed...
like this...  CRLF between lines
<header line> CR LF <text line 1> CR LF <text line 2> CR LF <text line n> CR LF
Is this a known phenomenon, or am I seeing things?
Don't ask a question if you aren't willing to listen to the answer.
