Author Topic: "LED's" or "Lead's" boxes or -/\/\/\-  (Read 19506 times)
Offline blueskull
  • Country: cn
  • Power Electronics Guy
Re: "LED's" or "Lead's" boxes or -/\/\/\-
« Reply #75 on: November 25, 2016, 07:09:57 am »
(the 's were fixed. I type faster then I think.)
They "were" fixed, so they are no longer fixed now?
Also, I think it's always a good idea to think before you type.
Depends on your use of the word 'fixed'.
If it is the past tense of the verb to 'fix', then the fixing action has been completed - and 'were' is used correctly.
If it is used as an adjective to describe "the 's" then blueskull's criticism is valid.
IMHO in this case, the OP wanted to stress the current state that the mistakes have been fixed now.
Therefore, I think present perfect simple tense should be used. Otherwise his words can be potentially interpreted as the effect of fixing is no longer valid now.
Offline timb
    • timb.us
« Reply #76 on: November 25, 2016, 09:05:23 am »
(Just like that Oxford comma I just snuck into that sentence. Also no longer correct per the Associated Press style guide and others, and more controversial. "Let's eat, grandma!" vs "Let's eat grandma!" :) )
Capitalization, Punctuation and Grammar Matter:
"I helped my Uncle, Jack, off a horse."
vs
"I helped my uncle jack off a horse!"
The more you know! ~~~#
Offline darrellg
« Reply #77 on: November 25, 2016, 04:38:19 pm »
vs
« Last Edit: November 25, 2016, 05:25:35 pm by darrellg »
Offline CraigHB
« Reply #78 on: November 25, 2016, 05:24:00 pm »
Commas are funny things.  I was taught years ago in grade school that you should use one any time a part of a sentence can stand on its own.  Doing that you end up with a lot of commas.  Now I favor using them only when the meaning is different with and without the comma.  I was using them a lot to pluralize acronyms, but came to realize that's not a proper use of a comma, makes the acronym look possessive.  People still do that a lot though.  I sometimes do it myself inadvertently.
Offline IanB
« Reply #79 on: November 25, 2016, 07:20:41 pm »
You have confused me there, and possibly yourself as well.
A comma sits on the bottom of the line, like this -> ,
An apostrophe sits above the line, like this -> '
They are different punctuation symbols with different names and uses.
The following users thanked this post: PointyOintment, Richard Crowley
Offline Richard Crowley
  • KE7GKP
« Reply #80 on: November 25, 2016, 09:11:09 pm »
Our European (and European-descendant) friends seem to use the term "inverted comma" for the mark we call "apostrophe".
Offline Fsck
  • sleep deprived
« Reply #81 on: November 25, 2016, 09:13:00 pm »
SCPI = "skippy"
SciPy = "Sci Pie"
"This is a one line proof...if we start sufficiently far to the left."
Offline IanB
« Reply #82 on: November 25, 2016, 10:54:38 pm »
I am native born British, having grown up there and spent most of my life there, and I do recall the term inverted comma now that you mention it. However, it is maybe something used around children to avoid them struggling to say (and spell) apostrophe. Apostrophe has always been the formal and correct word, as evidenced by, for example, Keith Waterhouse's AAAA (Association for the Abolition of the Aberrant Apostrophe).
« Last Edit: November 25, 2016, 10:56:30 pm by IanB »
Offline Halcyon
« Reply #83 on: November 27, 2016, 07:11:19 am »
I used to always pronounce the letters of LED, until at one place I worked we somehow started an ongoing joke of insisting that all acronyms must be pronounced as words.  This was in the days when laptops had PCMCIA slots...
But "Pik-Mik-E-Ah" is so fun to say!
It was reasonably common in Australia to pronounce PCMCIA as "P-C Mica", but to me it just sounded wanky. I always pronounced all the letters as in P-C-M-C-I-A.
Offline Brumby
« Reply #84 on: November 27, 2016, 12:34:27 pm »
Me too.
Offline jhalar
« Reply #85 on: November 27, 2016, 10:36:00 pm »
I know a lot of Aussies who are dead against "rowter" because we take a direct "root" not a direct "rowt". I kinda agree but I still say "rowter" instead of "rooter"
Working with computer networks for 20 years my mind is conditioned to say 'rowter' when talking about network routers and bus 'root' when travelling.
Offline PointyOintment
  • ↑ I scanned my face
« Reply #86 on: November 28, 2016, 12:40:20 am »
SATA: to rhyme with NASA
SATA: Serial Aye Tee Aye
So you pronounce it "say-tay"?
If you don't pronounce it is as a word, it's not an acronym—it's an initialism.
But with more and more things like Compact Disc becoming "CD" in formal writing, typing C.D.'s or later CD's went out of vogue with the formal writing crowd and now they appear to pluralize via capitalization only.
But " 's " was once the accurate, formal, way to pluralize an acronym.
That's not an Oxford comma. "accurate, formal, and way" vs. "accurate, formal and way" demonstrates the Oxford comma (but doesn't make much sense). Oxford comma is not even a valid concept, AFAIK, in the context of listing adjectives before a noun without the use of 'and'.
Offline denverpilot
« Reply #87 on: November 28, 2016, 01:19:17 am »
True, bad example of the comma, but the point was, style guides change and unless you're making a living with formal writing, you'll write it the way you learned it. The pluralization by " 's " once was just fine.
Offline Brumby
« Reply #88 on: November 28, 2016, 04:19:21 am »
Not where I come from.  The apostrophe was always to indicate the possessive form or for a contraction - never pluralization.
Offline blueskull
  • Country: cn
« Reply #89 on: November 28, 2016, 04:26:01 am »
I also see 's used to indicate plural a lot, but I never managed to find any explanation on any grammar books or grammar forums.
So I would assume the use of 's as a plural indicator is not grammatically correct.
More puzzling it is, some spell checkers will mark "LEDs", but not "LED's" (yes, I know why, but it just looks weird).
Offline Brumby
« Reply #90 on: November 28, 2016, 04:40:49 am »
That's my read on the subject.
From what I have noticed, there has been a fairly lax attitude on grammar since I was in school - and incorrect usage has gone unchallenged.  Even when it is, those who point it out are castigated with the tag "Spelling Police" or "Grammar Police".
Offline blueskull
  • Country: cn
« Reply #91 on: November 28, 2016, 04:46:58 am »
And even if schools teach and enforce formal English, people will just forget what they've learned after graduation.
In China formal British English is mandatory for higher education entrance test and high school entrance test, but most people will just forget these strict use of moods and tenses after being admitted into a college because in college, the focus of English education is for practical use, such as listening comprehension and professional English.
Offline vk6zgo
« Reply #92 on: November 28, 2016, 05:32:13 am »
When I was young,the term "inverted commas" was common in Oz,but it was a synonym for "quotation marks"( these things:-   "     "  ),not apostrophes.
We normally wrote them with  the "tails" down like ordinary commas,but I have seen them really "inverted",with the "tail" up,or occasionally with the one at the beginning of the quote "tail down" & the one at the end "tail up".
Back on topic,I think the "rectangular box" resistor symbol significantly pre-dated
computer drafting & was adopted to make it easier for manual drafting.
After all,a rectangular drawing aid was a lot easier to use than a "zigzag line" one.
Another possible reason was the fact that Industrial Electronics liked to draw inductors as zig-zag lines.
These days,computer drafting makes either resistor symbol easy to use,& zigzag lines for inductors never took off in mainstream Electronics.
Australia originally had more influence  from the UK & USA than from Europe,hence zigzag resistor symbols became the style of choice.
Japan uses them,too,so another "zig zag" influence was added.
As a result,even though the rectangle style is "supposed to be" the official symbol,both are in wide use.
In the end,both styles are easily readable.
Offline IanB
« Reply #93 on: November 28, 2016, 05:58:33 am »
The explanation is quite straightforward.
The plural of a word is formed by adding an s without an apostrophe, so for example board/boards, transistor/transistors.
An s with an apostrophe is used to mark possession, for example "John's boards came back faulty from the manufacturer."
However, apostrophes are also used to form contractions, by joining together two things that are normally separate, for example it is becomes it's.
This joining usage was at one time extended to forming the plural of acronyms or abbreviations, so for example the plural of LED would be written as LED's. The s is not part of the abbreviation, therefore it is separated with an apostrophe to indicate that it is something joined on, that it is not part of the thing being pluralized.
But over time, grammatical style has tended towards simplicity, and people started treating LED like a word rather than an abbreviation and therefore dropping the apostrophe in the plural and writing LEDs.
I would say it is still acceptable to write LED's as the plural, but such usage does seem to be dying out.
Offline timb
    • timb.us
« Reply #94 on: November 28, 2016, 11:17:28 am »
To me, that doesn't follow logically.
Think about it, abbreviations and acronyms pretty much always contain capital letters, so the "S" being lowercase indicates it's not part of the abbrevronym and is instead implying plurality.
Offline CraigHB
« Reply #95 on: November 28, 2016, 04:13:50 pm »
Haha, forgot to take my meds yesterday morning.  But yeah I meant apostrophe, not comma.  I guess I had a mental block about spelling that darn word.
I actually liked my English classes in college.  I enjoyed the ones most with writing assignments.  I like writing, that's why I visit various forums.
Offline eugenenine
« Reply #96 on: November 30, 2016, 12:03:49 pm »
My college english was pretty easy.  By then I already had several assignments from high school that I was able to simply open and re-print one of those and hand in.
  • KE7GKP
« Reply #97 on: November 30, 2016, 06:14:45 pm »
The only thing I liked about English class was diagramming sentences.  (Perhaps it reminded me of schematic diagrams.)
I remember this illustration from Scientific American back in the 1960s discussing the ambiguities in parsing language:
Of course, 50 years later Google (et.al.) has solved it by simply throwing MFLOPS at the problem.
Offline rolycat
« Reply #98 on: November 30, 2016, 06:37:56 pm »
Fruit flies like a banana.
« Reply #99 on: December 06, 2016, 11:18:11 am »
Reminds me of: http://www.huffingtonpost.com/2009/02/18/what-sentence-diagrams-re_n_167988.html
More: https://www.google.ca/search?q=obama+sentence+diagram&tbm=isch
I particularly like this one: http://www.german-latin-english.com/Barack_Obama_44.jpg (quite large so I didn't embed it)
