Author Topic: "Proper Units"  (Read 7407 times)
Offline DanHamerTopic starter
  • You can put a square peg in a round hole.
    • Carbon Frog
"Proper Units"
« on: May 21, 2013, 12:24:03 pm »
Just got around to making an avatar. You can't really see but its of some callipers that display measurements in "proper units". Here's a higher res image. ;D
Offline Psi
Re: "Proper Units"
« Reply #1 on: May 21, 2013, 12:46:25 pm »
id hate to see the size of the bee
Offline Skimask
Re: "Proper Units"
« Reply #2 on: May 21, 2013, 01:18:50 pm »
....as long as somebody doesn't have an avatar for "sex on a stick", I think we're in good shape  :-DD
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline veryevil
Re: "Proper Units"
« Reply #3 on: May 21, 2013, 01:20:38 pm »
should it be half a bees dick not half a bee dicks?
Offline dr_p
Re: "Proper Units"
« Reply #4 on: May 21, 2013, 01:24:25 pm »
Actually it's "half a bee's dick" :palm:
Offline steve30
    • Stephen Coates' Homepage
Re: "Proper Units"
« Reply #5 on: May 21, 2013, 01:35:48 pm »
Nice :)
Although my preferred unit of measure is the Nat's Whisker. I wonder if they make a caliper which measures in those.
Offline IanB
Re: "Proper Units"
« Reply #6 on: May 21, 2013, 01:46:34 pm »
Nice :)
Except gnat's whisker, with a "g"
    • Carbon Frog
Re: "Proper Units"
« Reply #7 on: May 21, 2013, 02:10:41 pm »
I don't want to be pedantic but if you are talking about an individual bee and comparing sizes of things to his dick then its 'half a bee's dick' as the dick belongs to that particular bee.
But if you are creating a standard unit then the unit is '1 bee dick' singular and if you are measuring things against that standard unit you will need a range that assumes more than one unit so your graduation should be labelled 'bee dicks' as in 10 bee dicks for example. That was my thinking anyway, I may be wrong grammar is not my strong point.
Offline c4757p
  • adieu
Re: "Proper Units"
« Reply #8 on: May 21, 2013, 02:13:14 pm »
Even if you get it wrong, your grammar's only off by half a bee's dick.
Offline dr_p
Re: "Proper Units"
« Reply #9 on: May 21, 2013, 04:00:06 pm »
 :-DD :-DD   :-+ :-+
Offline kfitch42
Re: "Proper Units"
« Reply #10 on: May 21, 2013, 04:23:18 pm »
Offline iloveelectronics
  • Country: hk
Re: "Proper Units"
« Reply #11 on: May 21, 2013, 04:27:56 pm »
I was taught in school that anything other than exactly one, we use the plural nouns/units. So "0.5 (or half) bee dicks" is correct, so is "half a bee's dick". "Half bee's dick" or "half bee dick" would be incorrect though :)
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Re: "Proper Units"
« Reply #12 on: May 21, 2013, 04:55:23 pm »
I don't think the bee was enjoying it though............. Nearly as long as the bee as well!
Offline ecat
Re: "Proper Units"
« Reply #13 on: May 21, 2013, 06:16:09 pm »
Half right, hehe.
It is indeed 0.5 bee dicks (as in naught point five or zero point five), as it would be 0.5 inches or 0.5 millimetres. But. If using half or quarter etc it becomes 'half a bee dick' or 'a quarter bee dick' as in half an inch or a quarter millimetre, more precisely it should be 'half of a bee dick' or 'a third of a bee dick'.
Edit:
Clarified difference between '0.5' and 'half'
« Last Edit: May 21, 2013, 06:24:08 pm by ecat »
Offline gibbled
  • VE7 call sign
Re: "Proper Units"
« Reply #14 on: May 21, 2013, 06:20:43 pm »
This thread reminds me of the monty python song about "Eric the half a bee"
Who ipso facto must half not be.   :D
Re: "Proper Units"
« Reply #15 on: May 21, 2013, 07:10:05 pm »
He 'ad an accident you see..............
Chorus.........
Offline IanB
Re: "Proper Units"
« Reply #16 on: May 21, 2013, 07:56:37 pm »
Not quite, though. Think of similar constructions, such as "half a day's journey" or "half an arm's length". For example, "I live not more than half a stone's throw away from my neighbour."
Offline ecat
Re: "Proper Units"
« Reply #17 on: May 21, 2013, 08:41:35 pm »
I started off agreeing but soon decided you are in fact cheating :p My sample base units are millimetres as in 'a millimetre' and inches as in 'an inch', your base units are 'day's journey' as in 'a day's journey', likewise 'arm's length' and 'stone's throw'. If for example your base unit was 'arm length' then the four 'arm lengths' rule applies as do the 0.5 'arm lengths' and third of an 'arm length' rules.
Dan summed it up earlier...
Offline N2IXK
Re: "Proper Units"
« Reply #18 on: May 22, 2013, 12:59:36 pm »
There's always this one:
But the conversion factor can't be right. 35 to the inch seems a bit coarse, no?  :-//
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
Re: "Proper Units"
« Reply #19 on: May 22, 2013, 03:01:55 pm »
All it takes is a wax to destabilize your whole economy of measurement  :-DD
Offline kfitch42
Re: "Proper Units"
« Reply #20 on: May 22, 2013, 07:54:38 pm »
And for a 'gold' standard do you need to find a blonde where the carpet matches the drapes :)
