Rpi and arduino are to electronics what lego mindstorms is to robotics.
A toy you play with. You may be a wizard with mindstorms but if i tell you : now go design a real robot arm including drive, that can do welding on a car chassis... You will end up nowhere.
Same with rpi and duino. Here is a bare chip , make a room thermostat with it .. Blank stare...
Your elitism is really wearing me out. I can't say you don't contribute, because of course you do. Far more than me, but come on. There are valid endeavors on this planet that you are not involved in and have not experienced. There are things that happen on non-industrial scales that are fully valid. Most of us have not been featured on the EEVblog or The Amp Hour, but that does not render our efforts or interests worthless.
Lego Mindstorms can be valid robotics. They are simply not at the same scale with the industrial robots I believe you are referring to. Nor do they have the same capabilities or performance characteristics, but that alone does not render it a toy platform. An Arduino IS a valid solution for some things, and not just toy things.
If an Arduino is a toy, then every low-end microcontroller is a toy. If an Arduino is a toy, why not an Intel 8051, which is STILL used to great effect in industry, and is LESS capable than an Atmel 328, which is the core of every Arduino I own?
If I have something I need to accomplish, and I can get it done with an Arduino or a raspberry pi, or KiCad or Lego Mindstorms, does that necessarily define any solution I come up with as a toy? Absolutely not.
No, we don't all have the same knowledge and experience as you. That does not make our efforts, interests, or platform choices necessarily irrelevant, and it does not make you automatically correct.
Despite my wording, I am not trying to attack you. I have much more to gain by coaxing you into helping more and dismissing less than I do by passing you off. I'm simply a crappy communicator, which leads to an inferred tone to my posts which is not intentionally implied.
