The Atten 938D mentioned before seems decent for the cost, I might go with that. I know you don't get the nice touches as you do with the real Hakko models, but they cost about 2x what they are worth here, you can almost buy a weller for a similar price. But in my opinion it is too much for the amount I use it.
My multimeter is definitely used most, and will be used more soon since I'm trying to build a power efficient circuit so the micro amp range will be important, something I currently can't do. On eBay fluke 87s aren't really that cheap, even used, I can find one for about £150 used, no probes, no fuse, by the time that's added it's £30 off the mentioned Agilent.
Has anyone tried the Agilent meter? There doesn't seem to be a huge amount of information on it unfortunately. I've seen the review of the older but higher model U1252A and it seems to work well, except for the continuity test. Does the U1241B suffer from the same issue? Also what is the battery life like?
The Amprobe AM-220 is a nice cost, and if I get a better meter, I'll probably get it as a second. I would really like a scope as I do need it sometimes, but I don't think it's enough to warrant the cost against other equipment, and if I get any scope I think it'll have to be a DSO as most things I need to check are for example clock rates, or power stability, sometimes also rise time.
I try to somewhat avoid used equipment unless it has been calibrated, the last thing I want is my test equipment to be off, then everything you do also is. Another reason I don't mind spending that bit more to get something I can trust. It's not like a mistake will cost me lots, but perhaps another set of PCBs and parts if it's enough of an error. Enough to make it annoying.
