Spent fuel is not really a problem. Remember that all the uranoim mined in the world is basically a recovered material from natural reactors, that operated for millenia, were in water soaked silts and muds, and where the remains are still contained there 450 million years later.
The deposits were made by erosion of volcanic rock which has Uranium group metals in it that were oxidised by the atmosphere as the rock eroded, and were washed down rivers to be separated naturally by mass into pockets of heavy minerals, and which were in turn covered with mud and silt till there was enough for a water moderated natural reactor ( higher concentration of heavy nucleotides then to start the reaction going) to start up and run for long enough to boil off the water, cool down and get wet again and repeat the cycle. This went on for a long time till the most active materials were exhausted, and the by products stayed in the same locations for the 450 million years, sitting in sandstone with water flowing through, till they were mined for the current power plant uses.
So choose, low level waste mildly radioactive for long periods, like living in Edinburgh on top of a massive block of radioactive basalt and granite, exactly like people love as a kitchen cutting surface and as a counter top all round the room, with some high level waste that will decay in a century to pretty much the same. Or live with a coal plant putting 100 times as much out into the air you breath, or a gas powered plant doing the same with Radon gas, or with solar panels made with toxic elements in them.
The reactors were in Gabon, at a little place called Oklo, and are a source of a lot of materials along with uranium.
