The working voltage would be determined by how the motor is built (number of turns in the coils, wire thickness, ventilation, max rpm of the bearings, etc) and Ohm's law.
Higher voltage is more current and more speed so more power and more heat.
And eventually something will break.
In a meeting modern PC the 12V rail would be the best choice to power the fans so they will be designed with that specification.
