Author Topic: A Burning CANDLE in Epoxy Resin  (Read 3099 times)
Offline Homer J SimpsonTopic starter
« on: June 21, 2020, 11:03:42 am »
This was just entertaining to watch...........
My mind starts thinking RGB and controllers.
The following users thanked this post: VK3DRB, BradC, SilverSolder, John B, james_s, syau, DrG
Offline VK3DRB
Re: A Burning CANDLE in Epoxy Resin
« Reply #1 on: June 23, 2020, 12:12:28 am »
Very interesting and entertaining. The same techniques could be used to make custom-made connectors, standoffs, LED light diffusers and bezels.
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #2 on: June 23, 2020, 05:12:07 pm »
No current limit resistor? :-[ :-[
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline John B
« Reply #3 on: June 24, 2020, 03:34:35 am »
It's actually pretty typical to just use a coin cell directly to an LED in $1 novelty devices.
However I would definitely want to have a proper driver circuit in this case to protect the LEDs. After all that effort, imagine blowing the LEDs... :palm:
Offline digsys
    • DIGSYS
« Reply #4 on: June 24, 2020, 03:54:52 am »
wonder how you could make it flicker !! that would be 4x cooler :-)
Offline james_s
« Reply #5 on: June 24, 2020, 04:53:30 am »
Any microcontroller could do that. There are at least a few that are in little SOT packages.
Offline JackJones
« Reply #6 on: June 24, 2020, 05:01:57 am »
There are LEDs with a controller built in that make them flicker like a candle. Flicker or candle LEDs is what they are called. A bit hard to get in SMD packages, they only seem to be widely available in 3 mm and 5 mm though hole variants.
Offline jonovid
    • JONOVID
« Reply #7 on: June 24, 2020, 05:48:08 am »
I would like to see some magic smoke captured in resin.
just the thing for Dave's lab,  ... an idea for mail-bag.
or how about have a cheap fake iphone charger pcb explosion
with the flash and flames captured in resin,
:popcorn:
Hobbyist with a basic knowledge of electronics
Online PA0PBZ
« Reply #8 on: June 24, 2020, 10:28:27 am »
Funny how the leds seem to light up under UV.
Online Yansi
  • STM32, STM8, AVR, 8051
« Reply #9 on: June 24, 2020, 01:30:05 pm »
White LEDs actually emit blue or UV and use a phosphor to create the white light. No surprises there.  ;)
The following users thanked this post: PA0PBZ
Offline DrG
« Reply #10 on: June 24, 2020, 06:41:26 pm »
true dat
Here is mine....I think they were 2/US1$ and included a CR2032. The 'flicker' is not that candle-like, but they do flicker. Nothing in them but an LED, on-off switch and the battery.
If you look carefully, you can see the IC inside the LED
Here is a head on shot
These are as good as I could get with my lens.
« Last Edit: June 24, 2020, 06:49:23 pm by DrG »
- Invest in science - it pays big dividends. -
Offline DrG
« Reply #11 on: June 24, 2020, 06:45:50 pm »
:popcorn:
Offline DrG
« Reply #12 on: June 24, 2020, 06:48:42 pm »
Here is another resin project. Very impressive but a FAIL (watch to the end). I really did like the way he used the fiber optics with LED shells.
BTW: lest anyone think I am being critical of the effort, I am aware that if I attempted the project the video would finish with me in the ER.
Offline james_s
« Reply #13 on: June 24, 2020, 07:36:20 pm »
Those flickering LEDs used in the little tealight candles never really impressed me much, they don't look candle-like at all. An actual candle doesn't really flicker much, it will waver a bit and may flicker in a breeze but the LEDs look quite exaggerated. I think a small microcontroller could do much better, especially with this candle that has two LEDs wired independently.
Offline DrG
« Reply #14 on: June 26, 2020, 01:39:45 pm »
No, they don't impress me at all either (as you could probably tell from my original statement).
I like this guy's empirical approach https://cpldcpu.wordpress.com/2016/01/05/reverse-engineering-a-real-candle/
The following users thanked this post: james_s, syau
