Author Topic: Self powering computer  (Read 2714 times)
Offline StonentTopic starter
« on: September 16, 2014, 06:19:15 pm »
There's a computer near a large robotic build cell that runs a line stats monitor.
If you remove all cables from the computer and plug in the video cable from the monitor, some of the computer's fans will spin up and stay spinning as long as the DVI cable is plugged in.
 :-DMM
During the break I'm going to check for a voltage between the DVI shield ground and the computer chassis.
Offline hamster_nz
Re: Self powering computer
« Reply #1 on: September 16, 2014, 06:33:46 pm »
HDMI/DVI has a 5V power signal. It is supposed to power the sink's EDID ROM so that the source can detect the sink's settings even when it is powered off.
However, when the monitor is on there is usually enough current to from the sink to power small devices - it is not very good form to use it though!
« Reply #2 on: September 16, 2014, 07:33:38 pm »
There's a total of 2 identical monitors feeding from that computer, one shares the outlet with the PC, and the other is about 20 feet or so away. I suspect they may be on different outlet circuits.
Offline abaxas
« Reply #3 on: September 17, 2014, 10:11:51 am »
Free energy! Fire up the kickstarter
Offline wraper
  • Country: lv
« Reply #4 on: September 18, 2014, 10:15:53 pm »
That is because of the stupid monitor design. I've seen that on one Dell monitor. There is power going from the computer to EDID eeprom (dual powered), there usually are 2 diodes in the monitor so the IC is powered from both sources. The thing is, monitor must not power a graphics card.
There is also another case with out of spec Displayport cables. There is one 5V wire that must not be connected according to spec. There is 5V pin on both ends intended to power active adapters and similar stuff. But they are not allowed to be connected together in the cable (tell that Chinese jerks). I've seen that myself with ebay Displayport cable which make computer unable to boot, also a spinning GPU fan if connecting a second monitor with the same cable. So I opened the connector and cut that nasty wire. There are actually a shitload of complains on forums about bad monitors which make computer unable to boot when connected with displayport. But they don't know that it is all about crappy cables.
