Author Topic: A Real-Life Tricorder! from The Signal Path.  (Read 751 times)
Online BrianHGTopic starter
    • LinkedIn
« on: July 22, 2023, 10:44:58 pm »
Complete demo and explanations of the physics on how it works.
The following users thanked this post: Andy Watson, Kean, newbrain, MK14, alm
Offline KE5FX
    • KE5FX.COM
Re: A Real-Life Tricorder! from The Signal Path.
« Reply #1 on: July 22, 2023, 11:30:30 pm »
Great presentation in this one, Shahriar's really outdone himself.  :-+  All it's missing is a teardown.
    • LinkedIn
« Reply #2 on: July 24, 2023, 05:11:20 pm »
Am I correct in understanding that the tricoder uses the change of angle of incidence from the directional laser's output, subtracting out the before waveform where the laser was in direct focus of the surface of the container with the afterm a general illumination of the container, to see through the plastic/glass container to analyze the contents inside, correct?
« Last Edit: July 24, 2023, 05:13:05 pm by BrianHG »
Offline helius
« Reply #3 on: July 24, 2023, 05:19:41 pm »
A collimated laser isn't really in "focus" anywhere. What they use is a shift in the spacing between the laser and detector. Knowing the angle of incidence and the angle of reflection, the distance to the target is a function of that spacing. If the target distance is inside the object, then the detected light must be reflected from inside the object.
That is why there are crossing aiming markers that allow for consistent placement of the OUT at the correct distance from the sensor head.
The following users thanked this post: BrianHG
