Author Topic: Servo Analog control  (Read 671 times)
Offline burningfireTopic starter
  • Country: ir
« on: December 23, 2018, 05:07:15 pm »
hi nerds  :-DMM
for a class project I need to build a full analog circuit for controlling a servo motor (using dc motor and gearbox ... )  . I searched a bit and also read a previous topic of this forum  : https://www.eevblog.com/forum/chat/circuit-request-servo-motor-feedback-control-circuit/
I know about it's feedback loop and how to use potentiometer and op-amp in it but here is a question :
Do I still need PWM or square pulses in my Analog control ?
 since hobby servos have three wires : gnd - vcc - and another one for pwm pulses , I didn't know if how and why I should use it in my analog design .
Offline donotdespisethesnake
  • Embedded stuff
Re: Servo Analog control
« Reply #1 on: December 24, 2018, 12:05:01 pm »
hi nerds  :-DMM
No, but you need some way to direct the position of the servo. It could be an analog voltage in the range 0-10V for example. Hobby servos use pulse width modulation - the width of the pulse in time determines the position.
Bob
"All you said is just a bunch of opinions."
The following users thanked this post: burningfire
Offline Benta
« Reply #2 on: December 24, 2018, 04:24:37 pm »
Search for "RC servo tester".
