I hope this question is electronics related enough to belong here.
I picked up an old motor from the tip-shop, looks like it's from a washing machine, and hopefully it's an AC induction type. There was no capacitor, and I can see no brushes.
There are two boxes on the end, one looks like a DPDT centrifugal switch, the other is as yet unidentified, and has 2 terminals.
There are 6 white wires which go to some kind of loom, numbered 2 through 7, 5 coloured wires too: Red, Blue, Red/White, Blue/White, Yellow/White.
There will presumably be a common, a run winding, and maybe 2+ windings for 2+ different speeds. This explains 4 of the wires, so I have some extra.
Attached is a schematic/diagram of sorts showing the switch and the connections, with all resistances as measured between all possible pairs.
I haven't tried connecting anything up yet, I want to be reasonably sure I understand it first before I either let the magic smoke out or the thing explodes in my face
- So - any ideas which wires could be which?
Thanks,
electronwaster
Edit: And of course if a photo would help, I will take one and upload it here. I can see no name/model/other markings on the motor other than the numbered leads.
