So, not only are we not allowed to damage a coin as Commonwealth Property for ANY intent, but we could even fall foul of Copyright. That seems pretty black and white.
OK - so coin zapping on Australian currency is off the table .... any other project ideas?
That makes sense, given that they all portray Queen Elizabeth II. Here, it would be George Washington and FDR, both long dead. Using a metal stamped with something familiar helps to see the result of the experiment, as I understand it. And I think the dime and quarter have basically suitable size and metal composition for getting good EM induction, as I recall.
Other projects that use high currents in short pulses? Well, I wouldn't recommend converting it to RF. Your local hams will be none to pleased about that. Besides, if you make it big enough it will be dangerous to nearby electronics. Such devices are produced, that can from a distance disable cars with electronic ignition even.
You could go kinetic. Time honored route. Not for everybody.
Maybe light? You could scrounge for gas discharge tubes used in stadium lighting, or something like that. Then see if you light it for 1 second!
