Author Topic: x-rays for looking inside electronic devices?  (Read 1264 times)
Offline engineheatTopic starter
« on: October 24, 2019, 09:08:03 pm »
I wonder if there are businesses that offer x-ray services to look into a manufactured product, like electronic devices without having to open and disturb the device?
Thanks
Offline tautech
Re: x-rays for looking inside electronic devices?
« Reply #1 on: October 24, 2019, 09:20:15 pm »
Hunt out some earlier threads from Fraser, he's done heaps of this.
He uses mainly dental units.
Offline oPossum
« Reply #2 on: October 24, 2019, 10:14:53 pm »
Offline Someone
    • send complaints here
« Reply #3 on: October 24, 2019, 10:20:05 pm »
Yes, they exist.
I wonder if you can form a better question?
Offline james_s
« Reply #4 on: October 24, 2019, 10:28:15 pm »
I've done it many times, using dental and veterinary equipment. The machines can be found surprisingly cheaply, expired film is also cheap and usually fine. It can be developed with ordinary photographic chemicals and can be handled under a red safelight.
Offline MosherIV
« Reply #5 on: October 24, 2019, 10:45:13 pm »
I am pretty sure many electronics board assembly companies may have x-ray equipment.
It is needed to inspect bga soldering.
If you can hire them to build boards, I am sure you will be able to hire them to x-ray things for you.
Offline james_s
« Reply #6 on: October 24, 2019, 11:25:50 pm »
I should have mentioned, while it's easy to do, it's also something that has the potential to be dangerous enough that you should absolutely not try it yourself unless you are really confident that you know what you're doing.
Legality aside, even a tiny little dental head has the potential to cause seriously nasty radiation burns, cancer or death if used carelessly.
Offline Sal Ammoniac
« Reply #7 on: October 24, 2019, 11:27:39 pm »
Do you need a license to own an X-ray machine in the U.S.?
"That's not even wrong" -- Wolfgang Pauli
Offline james_s
« Reply #8 on: October 25, 2019, 12:59:49 am »
To own? No. To operate it you don't technically need to be licensed yourself but it has to be an approved installation.
Offline SerieZ
  • Zap!
« Reply #9 on: October 25, 2019, 08:31:33 am »
Most serious PCB Assembly Factories have one.
As Pointed out earlier to inspect BGA and other Components Soldering Joints which are hidden under the Component.
Also sometimes they are used to try to find Problems and fix the more expensive Boards.
I dont think a Chinese Company assembling cheap Boards would have such Luxury...
Never heard of a Company offering just X-Ray services... I would not be surprised if it exists tho. Sounds so specialized tho it has to be expensive...
As easy as paint by number.
