Author Topic: 2017: The wheel  (Read 2514 times)
Offline ElektroQuarkTopic starter
    • ElektroQuark
2017: The wheel
« on: November 29, 2017, 08:25:44 am »
The following users thanked this post: BrianHG, CNe7532294
Online woody
Re: 2017: The wheel
« Reply #1 on: November 29, 2017, 09:42:03 am »
Looks like maybe King Arthur might have the patent on that technology  ;D
    • ElektroQuark
Re: 2017: The wheel
« Reply #2 on: November 29, 2017, 10:42:15 am »
Will it be the future on our cars?
Offline Cyberdragon
Re: 2017: The wheel
« Reply #3 on: November 29, 2017, 03:26:40 pm »
Nope, it'll end up on forklifts like the Twheel did. ;)
*BZZZZZZAAAAAP*
Voltamort strikes again!
    • ElektroQuark
Re: 2017: The wheel
« Reply #4 on: November 30, 2017, 07:45:13 am »
Didn't know about the Twheel.
Thank you for the reference.
Offline chickenHeadKnob
Re: 2017: The wheel
« Reply #5 on: December 01, 2017, 07:43:33 am »
I foresee one show stopping problem, small rocks which are just a tiny bit larger than the mesh size will be forced under pressure to be en-trained in the mesh or forced inside to be forever held captive. Like a pebble diode.
Offline Whales
    • Halestrom
Re: 2017: The wheel
« Reply #6 on: December 01, 2017, 08:27:53 am »
At faster speeds it'll be a varicap.
The following users thanked this post: IRFP460
Offline MadTux
Re: 2017: The wheel
« Reply #7 on: December 01, 2017, 05:44:19 pm »
Lol, these people at NASA are so smart, any well balanced car can drive on 3 wheels, doesn't necessarily need a forth one invented by NASA. But the average idiot will think NASA revolutionized the world once again  ;-)
Offline TerraHertz
    • It's not really a Blog
Re: 2017: The wheel
« Reply #8 on: December 02, 2017, 03:14:01 am »
What happens after one wire breaks? Does it unravel like an old sweater?
Down to what temperature does the wire stay springy, as opposed to brittle?
Also yes, pebble diode.  Needs some kind of spiral rubbish-ejector structure inside.
The wheels on the Mars rovers are looking pretty sad. Rocks keep tearing the thin metal sheeting between the thicker ribs of the cast metal wheels.
« Last Edit: December 02, 2017, 03:15:56 am by TerraHertz »
Offline retrolefty
Re: 2017: The wheel
« Reply #9 on: December 02, 2017, 04:06:07 am »
Won't work safely on earth because everyone knows that you can't have your car grounded through the tires contacting the earth.   :-DD
Online Kleinstein
Re: 2017: The wheel
« Reply #10 on: December 02, 2017, 09:09:41 am »
For use in roads there would be rather low friction - so not good for driving at any reasonable speed. Chances are also they would not last very long.
Those TiNi Alloys have a limited temperature range, but AFAIK not that limited to be a real problem.
That TiNi super eleastic material is really cool stuff. I once had a sample in hand at the university: It was something like a 3-4 mm thick rod, and one could bend it with bare hands to something like a horse shoe form and it came back perfectly. The elasticity is a little like rubber: once bend / stretched to a certain level, the force does not get much higher. There are frames for glassed made from such material.
Offline IanMacdonald
    • IWR Consultancy
Re: 2017: The wheel
« Reply #11 on: December 02, 2017, 06:51:14 pm »
"For use in roads there would be rather low friction"
I could see them being a LOT worse when wet, too.  :phew:
Offline cdev
Re: 2017: The wheel
« Reply #12 on: December 02, 2017, 09:23:06 pm »
This is great because continued use of rubber tires presents a major environmental problem.
Offline TerraHertz
Re: 2017: The wheel
« Reply #13 on: December 02, 2017, 09:33:46 pm »
Hmmm.... since they used the term 'chain mail', I wonder if this mesh could be useful for spacesuits? Make the mesh quite fine, then embed in something like neoprene, to get a flexible but very tough and puncture resistant material?
As a bonus it would be electrically conductive, so with care could make the spacesuit a complete Faraday cage.
