Author Topic: How does this work? Distortion Detector/Analyzer  (Read 2993 times)
Offline george gravesTopic starter
« on: October 02, 2012, 10:18:30 pm »
This is a tool for car audio guys to detect distortion when setting up  the gains on the stereo, amps, and other signal processing stuff.
http://www.sonicelectronix.com/item_61378_SMD-DD-1-Distortion-Detector-Analyzer-by-Steve-Meade-Designs.html?utm_source=google&utm_medium=cpc&utm_campaign=productads&gclid=CNjA8q-u47ICFShxQgodB34A3g
Any idea on how it works?  (it's not open source)
Offline Short Circuit
    • White Bream electronics R&D
Re: How does this work? Distortion Detector/Analyzer
« Reply #1 on: October 02, 2012, 10:28:44 pm »
Bandstop (or just highpass) filters for the original tones followed by peakdetectors with a level indicator LED.
Probably requires a substantial amount of distortion before it actually triggers.
Offline ejeffrey
« Reply #2 on: October 02, 2012, 11:00:34 pm »
The traditional THD(+N) meter is a high purity sine wave oscillator with a tuned notch filter that rejects the oscillator tone.  Any harmonics generated by the DUT will pass the filter.  The resulting signal goes through some type of level detector.  The performance of the meter is determined by the spectral purity of the oscillator and the depth of the notch.  You can also use bandbass filters to isolate individual harmonics, but normally THD is what you care about.
A modern version would digitize the output of the notch filter and use an FFT to identify the relative harmonic strengths as well as improve rejection of the input tone.
Offline poptones
« Reply #3 on: October 02, 2012, 11:04:46 pm »
He still had distortion when he did the midrange unit.
Funny. And ironic. Even on a youtube video I'd just use my ears. Always worked before.
