The only time I saw a tunnel diode from up close was a few years ago in a lab - the assignment was to measure (and later plot) the IV curve. If I had one I would not know what to do with it - after all, it seems to me that it would be easier to build a transmitter with vacuum tubes than the tunnel diode (since IIRC all tunnel diodes are low power, so I would still have to use tubes to amplify the power). However, since I am incapable ow inding a coil (so it has specified parameters), I won't be building any transmitters any time soon.
