Author Topic: Advice for tape/sealant for Saab rear window trim  (Read 627 times)
Offline etiTopic starter
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
« on: June 10, 2020, 10:52:09 pm »
Hello!
My friends, I need some help - can you recommend a solution to coat the rear-top seal of a Saab rear window? The seal integrity is fine, but there is a black painted strip of metal above it, where the black paint has worn off, over the years. I had suggested self-amalgamating tape (as used for weatherproof seals for sat dishes - we used to use that a lot) but I wasn't sure if this would be correct advice.
If you know, would you reply? Many thanks me old Chinas.
Offline helius
Re: Advice for tape/sealant for Saab rear window trim
« Reply #1 on: June 11, 2020, 01:05:31 am »
Self-amalgamating tape is for wrapping leaky hoses with overlapping layers.
Are you looking for an adhesive, or a paint?
The following users thanked this post: eti
« Reply #2 on: June 11, 2020, 01:27:15 am »
I am looking for a paint. Thanks! :)
Offline deadlylover
« Reply #3 on: June 11, 2020, 01:38:34 am »
Hmmm how about plasti dip? Should be able to find a can easily at your local auto parts store.
Easily removable and I think it will match the look of the original paint (sort of dull and slightly matte, it isn't shiny).
Offline Lord of nothing
  • Country: at
« Reply #4 on: June 12, 2020, 11:23:40 am »
Does we talk  about such Saab Product?
Made in Japan, destroyed in Sulz im Wienerwald.
